Bill Douglas's Avatar
Protection using iso-cyanates.
I'm an occasional painter - garage style. I've done a few day classes, and painted a few panels.
But I'd like to use paints with hardeners, iso-cyanates in other words. And epoxy primers. I can paint outdoors so I don't need absolute protection.
What do you guys use or think of as being an acceptable minimum for an air feed respirator setup. I had been considering a second hand 3M Dustmaster and having the box upwind (or outside of the garage) and a longer air tube.
Old 04-25-2021, 01:14 PM
greglepore's Avatar
I like that idea. For occasional use, it'd probably be fine. I wouldn't clear an entire car with that setup, but for limited exposure etc you'd probably be ok. I'd mount the intake as high up as possible. I don't know how powerful the fan is, might have to upgrade to a higher cfm unit if the hose run gets long.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 04-25-2021, 02:39 PM
Navin Johnson
TimT's Avatar
That is probably fine as long as you use the correct cartridge.
Also wear a Tyvek suit nd cover as much of your skin as possible.. isocyanates can penetrate your skin..
'69 911 GT-5
'75 914 GT-3
and others
Old 04-25-2021, 02:42 PM
Thanks Greg, thanks Tim.
Old 04-26-2021, 05:36 PM
greglepore's Avatar
Second the reco for cheap tyvek suits. Disposable, local auto paint supplier has them.
Greg Lepore
85 Targa
Old 04-26-2021, 06:44 PM
Will do, thanks.
Old 04-26-2021, 07:11 PM
