| Just thinking out loud Join Date: Nov 2001 Location: Close by
			I'm confused.  Not sure how the bearing wallered out the shaft.  The bearing is inside the pulley, which rides on the nose of the front housing.  The shaft runs through the nose. Anyway, if you have time, I can seal this one up and send it your way. I don't think I have a case seal kit for it on hand, I'd have to check. I might could send it next Tuesday? All depends how quick I can, if I need to, get parts. There are some aftermarket 10PA15C's that are alright. The Denso OEM I have is off my buddies tacoma, he has over 150,000 miles on the replacement compressor I put on. I can't remember what brand it was. Just let me know what direction you might want to go, and I'll do what I can to help out.
				__________________ 83 944 91 FJ80 84 Ram Charger (now gone) | ||
|  06-17-2021, 04:42 PM |
			It was a Valeo.   If the front nose is mangled, you need to take it farther apart to replace what is bad, that will require removing the 6 allen head case through bolts. I believe they are 6mm, might be 5, I forget. Then replace that with a new (to you) nose piece and case seal. New bearing, and what you have that is still good, likely the pulley, coil, clutch, and you are good to go.
|  06-17-2021, 05:01 PM |
| Model Citizen Join Date: May 2007 Location: The Voodoo Lounge
			Matt, I sent you a PM...
				__________________ "I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" | ||
|  06-17-2021, 05:22 PM |
| Registered |
			I have a better solution.   You need a project car!
				__________________ 1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? | ||
|  06-18-2021, 06:05 AM |
I need to get a real dd and make this my project car.   It's such a good truck and so easy to work on.  And it's probably worth close to as much as I paid for it in 1992.
|  06-18-2021, 07:23 AM |
			Public shoutout to mattdavis11 He's been over and above helping me with advice, information and parts. I'm not up and running yet, but at least I'm confident I'm on the right track and this is something that "average Joe" can do. Thank you Matt.
|  07-04-2021, 06:44 AM |
			You are very welcome, sir.  Let me know if you need help along the way.
|  07-05-2021, 06:08 AM |
| Registered Join Date: Oct 2003 Location: Roseville, CA
				 | Quote:
  Crazy
				__________________ 1992 968 Polar Silver 2010 Toyota Highlander SE 2006 Lexus LS430 ML | ||
|  07-05-2021, 10:34 AM |
