My other ride is a C-130J
WiFi Router Lifespan
I’d like to see the group’s experience with their home WiFi Routers.
My current unit is 2 years 8 months old and is acting up. Devices will lose connection and I need to frequently reboot (unplug then replug) the system to get it to work normally. Tonight I had to do it twice. My hard wired Ethernet devices are also experiencing connectivity problems. My internet service provider recently upgraded the modem so that likely is not the culprit. How long are you getting out of your WiFi Routers?
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A Last edited by RNajarian; 06-18-2021 at 10:54 PM.. |
Brew Master
4-5 for me. I had an older ASUS that recently stopped working. My TP link is going on 3. I have an actiontec (from CenturyLink) that is 4.
Oh sh.t! I just realized I'll be in the market for two new routers in the next year or two! ![]() Check for a firmware update on your router.
Nick |
I upgraded my last router only because I went to Gigabit speed and the old router could not handle that.
My 89 year old Mother in law has the same wi-fi router I gave her many years ago. It was one of mine that I had changed out for a new one for a better signal to my garage. Her router is at least 7 years old if not more. I would guess it is 9. She has a smaller house, and is happy with slower WI-FI and all she does is email and a bit of Amazon buying and download books for the library.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
canna change law physics
I said 2-3 years because I change them out about every three years to the newer technology. I have "AC" routers, but my cell phone can handle "WiFi 6".
What amazes me is how many "new" devices can only work on 2.4 GHZ. My pool robot and the WiFi Thermostat (which I really didn't want) are 2.4 GHZ only. I think they are the only things that connect at 2.4 GHZ.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
If my MIL lived in a heavily populated area I would upgrade her wifi just for more security.
The Unsettler
Those remote devices use 2.4 because they are generally the farthest away, only pass small packets of data. They don’t need a more robust connection and actually perform better over 2.4
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
I think I've had one router that required replacement, and that was probably 10-15 years ago. Otherwise, I probably get at least 4-5 years out of them, and when they get replaced, it's due to circumstance (change of SP that gave me a new device, wanted a new device for new features, given a new device by SP because my old one was old, etc...)
Flat Six
^^ If you're having this issue and your hard wired Ethernet devices are running through a separate router, then the issue is upstream. Might be with the new modem, its physical connection to your ISP, or even the Ethernet connection between modem and router. I typically get a new WiFi access point every ~4 years or so. Netgear or TP-Link for me. Haven't had any performance or reliability issues, but periodically upgrade because our needs change -- for faster/stronger signal, easier access management, and improved security. If you end up replacing your WiFi router (actually, even if you don't) I'd suggest connecting your modem to a stand-alone Ethernet router and connecting your WiFi router to that, effectively using your WiFi router as an access point.
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
I think we've had out for eleven or twelve years. I haven't even thought about replacing it.
Marv Evans '69 911E |
I replace mine each time I get a speed bump in my service from Windstream for the actual router part.
But I only use it as a gateway to the internet, actual routing is handled by either a Pi or a 32bit media center PC both running Linux, depending on which network something is connected to in the house. I do this for a few reasons - 1 - I can 2 - security since I don't know what crap my daughter installs on her phone and computer 3 - security since I don't know what crap my son installs on his phone and computer 4 - access control - able to block on network level via DNS for ads and places the kids shouldn't be for whatever reason 5 - bandwidth conservation/limiting so I always have enough to do whatever I need to do for work, etc. |
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A Last edited by RNajarian; 06-19-2021 at 09:22 AM.. |
Brew Master
Have you tried a 30-30-30 hard reset?
Nick |
I’m going to have to look up what that is . . .
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
Brew Master
Don't know if it will fix your issue but it might be worth a try.
Nick |
Thanks, I may have to give this a wangle.
It sounds like I will need to reassign the SSID and password once I do it. Better dig out the instruction manuals
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A Last edited by RNajarian; 06-20-2021 at 07:48 AM.. |
If one is interested in the latest faster Wi-Fi tech, then new is the only recourse since they are hardware based upgrades.
![]() I never get the 1024 Mbps like they advertise, but it is still way faster than any web site I have visited. Mostly I don't care about all the download speed, and I pay for the speed only to get the 35 Mbps upload speed. I upload 2GB files and larger to our One Drive site for our customers.
Since upgrading my Comcast router/modem, I no longer need to use my wi-fi extender that I have on my outdoor deck.
New Router... Full five bar strength with the new....2-3 with the old.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
I live in a neighborhood with almost everyone using a WI FI router.
I have a 5Ghz and a 2.4Ghz network. Actually I have two 2.4Ghz Networks. My wife uses one, and I use the other for my phone and laptop. The 2.4 seems to go further and have a better signal in the garage for my iPad to play Pandora. If I do a search for networks there are at least 10 if I stand in the front yard. When I got my first router it was the only one around. Now they are all over.
D idn't E arn I t
Consumer grade crap from Best Buy etc. are typically only good for few years. Planned obsolesce.
rjp
In the movies only bad guys sleep in king size beds. |
