VW Engine Swap
Might be better to post on The Samba but with the wealth of information here, hoping some can weigh in.
How plug and play is putting an '85 Cabriolet FI engine into an '80 Scirocco with a carb? Considering taking the engine and trans out of my Cab and putting it in a Scirocco. Fuel pump is obvious. Maybe engine wiring harness too?
Tru6 Restoration & Design |
Team California
What 1980 Scirocco came with a carburetor?
![]() They are CIS cars since about 1974, same as a 911 from the same period.
Denis |
One that someone converted. It’s got a 1.8 with a Weber carb.
cycling has-been
I seriously doubt that any advice/information regarding this swap will include the words 'plug and play' anywhere in the narrative.
73 911T MFI, 76 912E, 77 Turbo Carrera |
Platinum Member
Think outside the box. Cut the roof off the Scirocco and graft it onto the Cabriolet.
Or in other words, I have no constructive advice.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Well this is good news. I'll either swap just the injection or may be easier to swap entire engine and transmission in one piece + the CIS from the 85 to 80.
Platinum Member
How hard it's going to be depends on what they did to change it to carb.
CIS will need a supply and return line, if the lines on the Scirocco have the ends cut off or are otherwise mangled you can conceivably use the Cabrio lines, but I'd buy new unless they were perfect. One thing to consider is the 85 is likely CIS-E, and the project would be immensely simpler to install an older CIS system without all the electronic crap. If there's a 1.8 in the Scirocco now, it didn't come with that. You'll need to know the compression ratio to proceed. |
New lines are the way to go, I agree.
There's that big of a difference between 80 and 85 for the CIS? I feel like trying to put together an early CIS system would put me in a world of hurt.
There's a reason somebody put the weber on the Scirocco.
VWs up to about 80? 81? used a purely mechanical fuel injection, other than maybe a heater in the warm up regulator because it didn't warm up fast enough for the government. Shortly after that they added a Oxygen sensor and a valve on the fuel distributor to try to control the mixture. The 85 probably also has a solid state ignition where the 80 would still have points. I'm probably biased because all my VW tuning was on the early cars, you could probably swap everything over and not have a problem, but I wouldn't do it. |
Years ago, I often pondered the idea of an air cooled Porsche motor in an Audi 4000. I think the carburetor/fuel injection would be the least of your problems.
Wouldn't swapping motor/trans/CIS all in one be the best solution? There is a chance I can get the Weber to work properly, just not likely. It yard drives, even around town drives, but that's about it.
Tru6 Restoration & Design Last edited by Shaun @ Tru6; 06-29-2021 at 01:34 PM.. |
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Hell Belcho
Honestly, a Weber would be far easier to setup and tune...
Saved by the buoyancy of citrus. |
The CIS on the Cabriolet works fine. That's one reason I would move everything over to the Scirocco. The Weber is an unknown quantity to me. I don't know who installed it, what they did right/wrong, why, etc.
Team California
Denis |
Does it have to be OE stuff? Could you use an aftermarket solution like Megasquirt? CIS to EFI Conversion
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Jared has me convinced to work with the Weber first. A set of headers, not mounted, come with the car, those might be neat. Looking forward to driving to Colorado and towing it home on a dolly soon.
my first project vw rabbit ... .. covert diesel to fuel injected
if you want me to tell you lets talk anthony |
