Got a picture of the thing?
Yeah, got a picture?
Does this pergola have a roof that could act like a giant 'sail' if the wind caught it? If so, I can see the need/desire to anchor it. Our patio 'cover' is only held down with four bolts total, but it's so 'porous' the wind couldn't lift it if it tried.
Scott '78 SC mit Sportomatic - Sold |
canna change law physics
I hate drilling concrete. I always seem to hit a piece of aggregate...
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
James, I use a rotary hammer drill to drill concrete. It goes straight through aggregate. Ryobi - cheap as chips and goes at concrete like a Rottweiler.
It's usually the rebar that gets me torqued.
If you go with wedge anchors and I think they are a good choice for this, make sure they are shorter than the thickness of the concrete, drill the hole much deeper than the length of the anchor (don’t want it to bottom out), get the dust out of the hole, put the washer and nut on the top flush, drive it down as far as it goes then tighten the nut.
Lots of people try and drill a perfect depth then put the anchor in the hole and then add the washer and nut- usually it sits too high and you end up with too many threads above ground.
Rutager West 1977 911S Targa Chocolate Brown |
The Unsettler
A good argument and one that would convince a wife are two completely different things and at least one of them is a Unicorn.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Brew Master
Nick |
![]() So I suppose it's technically possible it could lift, but I feel like if it's ever that windy, we will probably have bigger problems to deal with.
1992 968 Polar Silver 2010 Toyota Highlander SE 2006 Lexus LS430 ML |
That has a fair bit of sail area. Not sure what the sail area to weight ratio would be.
87 930, |
Two anchors each of the corner posts ought to do it; if you want to make it symmetrical two anchors at all six…
I have no idea how the roof structure is connected to the posts, that might be an argument for all six. I would use half-inch anchors. |
I used these exact brackets with a fence that I built and installed on top of a concrete patio.
I recommend using expanding concrete anchors. I used 1/2" x 3" and once the hole is drilled (pain btw) I tapped the anchor into the hole and the posts are not going anywhere. I like the idea above where you are temporarily moving the pergola. However, that may be easier said than done - especially if it is attached to the house. Maybe you could attach some type of 2x4 to the post and use a floor jack to jack up just enough to get the bracket onto the pergola. Then set it back down and drill your holes. |
I did not use anchors for mine and it's as solid as a rock.
Drilling holes with the post bracket in place probably means your holes will be drilled at a angle.
Old dog....new tricks..... |
Model Citizen
The permanent solution. Here's what I'd use to glue the all-thread into the concrete. I've used it before and if you follow all the instructions, especially regarding getting all the dust out of the holes, this will cure harder than the concrete and grip that thread so hard it'll take an act of congress to remove it. I'll bet two fasteners per post would be plenty, too. (set at the diagonal)
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Model Citizen
Just out of curiosity, is there a good reason that the original builders didn't install fasteners in the first place? I mean, they might as well have just set the end of the post on the ground....
[QUOTE=herr_oberst;11437022]The permanent solution.
grip that thread so hard it'll take an act of congress to remove it. /QUOTE] Good advice, but I didn't use any adhesive because at some point I will be removing mine and do not want to make the job any harder than it already will be. Using an impact wrench is the way to go, BTW.
Platinum Member
![]() Remove Trim highlighted above. Add tie down straps, and replace trim to hide. Hurricane Sandy, my pergola:
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Ayo Irpin, Ukraine!
We don't mess with anchors, they are not as secure. I've seen wedge anchors pulled out before. If it works with the wind loading of a 13M antenna reflector,,,,,,
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
