We plan on two months or so towing a version of your trailer, going places I have wanted to spend more than a day or two in. The UP and upper Midwest is an area I haven't been to since I was a child. Thanks as well mjohnson.
1996 FJ80. |
Fleabit peanut monkey
I did not mean this as a negative. You are way outside the norm in the Dallas area. It is strange.
Houston has the Guff of Mexico to temper. You guys got nothing.
1981 911SC Targa |
Mighty Meatlocker Turbo
100 currently, with heat/humidity index of 108 - forcast to still be in the 90s after midnight tonight. More of the same for the coming days. Burn ass! |
I think that heat index might be just a wee bit high.
Now shows index to be 105 on Weather Underground (don't know how accurate WU is though).
What zip?
Everything I’m seeing is less than that. |
I just checked the weather underground site and it shows is 1° cooler on the air temp and 5° warmer on the way heat index than the national weather service in my area.
I think their heat index values are out of whack. The weather channel values are always a couple degrees warmer for the air temp than the national weather service, also. I just checked the weather channel heat index and it’s a whopping 9° higher than the national weather service. Last edited by javadog; 09-04-2021 at 01:51 PM.. |
So, just for ****s and giggles I calculated the heat index for all three sources using the air temp, dewpoint and humidity numbers they show. National weather service was right on the money, weather underground and the weather channel are way off.
I’m surprised, you e would think that would be pretty easy to get right. |
Some might say a little chilly, even.
1981 911SC Targa |
Javadog, zip is 76133. Very interesting about the inconsistencies between weather info sources.
Bobasaurous, I was plenty comphy today as I spent most of the day at home, basking in a combined 5 tons of glorious a/c (3 ton central air along with a 2 ton Mitsubishi mini-split in the part of the house I use the most . . . let me tell you that that thing rocks out with its c**k out ).
I see you
https://www.google.com/maps/@45.2081903,-85.5429214,1144m/data=!3m1!1e3
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
