Whoopsies I was banned!!!
Alternatively two 100lb strippers with 1.5 ft of their dance pole cut out would go well beyond satisfying the minimal requirements and permit the OP to simply supervise the task.
Hehe, it's important to not overthink this.... |
For the nut on the rear axle of my 911 the torque value is some crazy number like 360 pound feet. I would have to look it up to get the exact number and it is irrelevant right now.
I stood on a scale, and pushed down on a 3 foot bar until I weighted the proper amount on the scale. Again, I don't remember the numbers, as it does not matter. I then knew I was pretty close, but I don't do "good enough" when it comes to holding my rear axle on. I brought my socket to a local truck stop and pulled up by the work bays. Of course an old guy in a 85 911 with a $20 bill in hand attracted some attention. One mechanic walked over and I told him I would give him the 20 if he would torque the two nuts to the proper number. He grabbed his 4 foot long torque wrench, and click click twice and he made 20 bucks. I went home and put the cent caps back on and I was done.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I think 300ft lbs is right on the edge of most half inch drives capacity. Can grab a decent ratchet and torque til it breaks and you will be close
if you have the right 3/4 drive socket and breaker bar you can get something like this for relatively reasonable amount. https://www.amazon.com/Neiko-20743A-Digital-Adapter-Foot-Pound/dp/B009GLITFW/ref=sr_1_2?dchild=1&keywords=torque+adapter+3%2F4&qid=1632147711&sr=8-2
84 930 18 Cayman GTS |
I have a DeWalt 20v impact. Used it for axel nuts that are around the same torque. Prior to that it was a 3/4 drive socket and 3.5 ft breaker bar with my fat ass standing on it.
Matthew - drove Nurburgring with wipers on and no rain 1969 911E SOLD ![]() 2002 996 Cabrio 1995 993 Carrera 4 SOLD 2004 Land Rover Discovery II G4 Edition (Sold )
Team California
Any really strong impact wrench should do it. You would need to torque it to 250, or however tight you can accurately get it with your wrench, mark the bolt with paint and then blast it with an impact that moves it a hair. Just a hair, at those torques. Threads only stretch so much.
The suggestions about having strippers or 4 German Shepards standing on a pipe assume that there is no friction to overcome in initially moving the fastener. That is an incorrect assumption.
Denis |
Team California
Denis |
Lots of snow Porsche away
The torque value is given with drag torque included. Where it is not, then it would have to be measured and added to the total torque, and the torqueing procedure would indicate that.
76 911S 86 GMC K1500 78 XS750 cafe racer to be 79 XS750 because one is just not enough |
D idn't E arn I t
TQ wrenches aren't exactly accurate at the top of the scale they are rated for. Min / Max tq. measuring capacity +/-20% IIRC.
I'd seek a tool rental place out, frankly. rjp
In the movies only bad guys sleep in king size beds. |
Team California
No, they do not. If a fastener is already tight, (i.e. anywhere close to final torque), it needs to be loosened slightly and then torqued. Torque wrenches absolutely do not account for initial friction and would *click* below final torque in that circumstance. They are made to measure while moving.
Denis |
I’ve always read the bottom and top scales of the torque wrench are not as accurate. That said, I torqued it to 250 and then used my breaker bar with a 3 foot cheater bar to move it a little more.
Speeder is correct. Torque a moving bolt, not a tightened bolt. And adding lube for good measure may not be advisable.
The accuracy is typically a percent of full scale. So you want to use your torque wrench near the top of its range. The top end is the more accurate region.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Is this accurate? I've always tried to pick a torque wrench where the "desired" torque is in the middle of the wrench's range and not the upper end... but I dunno.
I will modify my statement to say 'it depends on the wrench'. Read the docs that came with your wrench.
What I stated is 'typical'. So it might be both accurate and repeatable...
?I have 20 year old Craftsman TWs ... anyone know about them? Learned something new.... thanks! |
I'm surprised that BMW would have torque value like that rather than a pre-torque value and then a turn X degrees number. That's what modern Porsche's do for flywheels and such.
Torque wrenches aren't super accurate for determining bolt stretch anyway. You could calculate the turn by degree method with the thread pitch and desired bolt stretch.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
abides.
Just give it 7 Ugga Duggas and you should be fine.
Graham 1984 Carrera Targa |
Sold: 1989 3.2 coupe, 112k miles |
