Torque wrench how to question
I need to torque a bolt to 305 foot pounds. I have a 1/2 Snap On that goes to 200 and a 1/2 Kobalt that goes to 250.
If I use one of them set at 100 ft lb and use a 3 cheater tube on it, will that get me 300 ft lb? I need to get this installed tomorrow, and looking online, I dont see one available nearby. |
Almost Banned Once
This link should help.
https://www.terex.com/docs/librariesprovider7/tech-tips/techtip_53.pdf?sfvrsn=1371ae74_10
- Peter |
No, but it will make it a lot easier to torque 100 lb-ft
You meant to say 30 foot cheater, right?
15 pound barbell weight, tied to a 20 foot cheater, on a 3/4 drive breaker bar is 300 ft/lbs. So is a 100 pound weight tied to a 3 foot cheater bar. Just take biggest breaker you have, and stand on it. You'll get close enough.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Yep, can't use your current torque wrenches to make this happen.
You do not have permissi
300 ft/lbs on a 1/2" torque wrench will probably be best using the Snap-off brand.
(Round-off is the correct 12pt socket to use) I've used those before while jumping on cheater bars. You'll get brand new tools as a bonus. See if someone (tractorsupply/bigbox/autoparts) carries torque multipliers and impact sockets.
Meanwhile other things are still happening. |
Checked out
I have the same issue currently. I need 325 ft lb. on a front crank hub nut. I went to a long time shop in my area to see what they do. I was surprised when they told me they dont have a torque wrench that goes up that high, they just do it as tight as possible. |
Checked out
It took all of my effort with a 4.5 foot breaker bar to get the nut loose.
And that’s with PB Blaster and a propane torch. |
When I typed my question, it didnt sound right for torquing a bolt. Ill torque it to 250 and see what I can do after that. I used a six point impact socket on a 18 inch breaker bar and a 3 foot galvanized pipe to break it free. I wasnt sure my the flywheel pin would hold.
Other options: 1/2" electric impact will get you 300 lb-ft easily. A 2' bar with a 150 lb person will do it.... Axle nut? Last option: stop at a diesel mechanic shop. 300 lb-ft is finger tight for them.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Maybe you said above but didn't see it.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
I'm guessing 305 is about 250 plus a 1/16th-1/8th turn.
I like how it's 305, not 300, not 350, 305. It would have been even better if the spec said "307.3"
German engineering.
Anything out of .005% tolerances results in the front wheels bouncing a foot off the ground at highway speeds.
415 Nm
Information Junky
This ^
A 200 lb person stand on a 1.5-ft bar will do it too.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2’ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Are you 305 lbs? That makes the math easy...
Information Junky
LOL
nicely played.
