A930Rocket's Avatar
Torque wrench how to question
I need to torque a bolt to 305 foot pounds. I have a 1/2” Snap On that goes to 200 and a 1/2” Kobalt that goes to 250.
If I use one of them set at 100 ft lb and use a 3’ cheater tube on it, will that get me 300 ft lb?
I need to get this installed tomorrow, and looking online, I don’t see one available nearby.
Old 09-18-2021, 07:54 PM
Almost Banned Once
sc_rufctr's Avatar
This link should help.
https://www.terex.com/docs/librariesprovider7/tech-tips/techtip_53.pdf?sfvrsn=1371ae74_10
- Peter
Old 09-18-2021, 08:01 PM
mistertate's Avatar
No, but it will make it a lot easier to torque 100 lb-ft
Old 09-18-2021, 08:03 PM
You meant to say 30 foot cheater, right?
15 pound barbell weight, tied to a 20 foot cheater, on a 3/4 drive breaker bar is 300 ft/lbs.
So is a 100 pound weight tied to a 3 foot cheater bar.
Just take biggest breaker you have, and stand on it. You'll get close enough.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 09-18-2021, 08:05 PM
Yep, can't use your current torque wrenches to make this happen.
Old 09-18-2021, 08:34 PM
You do not have permissi
john70t's Avatar
300 ft/lbs on a 1/2" torque wrench will probably be best using the Snap-off brand.
(Round-off is the correct 12pt socket to use)
I've used those before while jumping on cheater bars.
You'll get brand new tools as a bonus.
See if someone (tractorsupply/bigbox/autoparts) carries torque multipliers and impact sockets.
Old 09-18-2021, 09:19 PM
Bill Douglas's Avatar
I think them saying 305 foot pounds is just a polite way of saying "Get the bolt tight as hell."
Old 09-18-2021, 10:12 PM
Checked out
McLovin's Avatar
No, but it’ll get you to 100 ft lb easier!
I have the same issue currently. I need 325 ft lb. on a front crank hub nut.
I went to a long time shop in my area to see what they do. I was surprised when they told me they don’t have a torque wrench that goes up that high, they just do it “as tight as possible.”
Old 09-18-2021, 10:58 PM
Checked out
McLovin's Avatar
It took all of my effort with a 4.5 foot breaker bar to get the nut loose.
And that’s with PB Blaster and a propane torch.
Old 09-18-2021, 11:00 PM
A930Rocket's Avatar
When I typed my question, it didn’t sound right for torquing a bolt. I’ll torque it to 250 and see what I can do after that. I used a six point impact socket on a 18 inch breaker bar and a 3 foot galvanized pipe to break it free. I wasn’t sure my the flywheel pin would hold.
Old 09-19-2021, 06:08 AM
Yea, have to agree.
Other options: 1/2" electric impact will get you 300 lb-ft easily.
A 2' bar with a 150 lb person will do it....
Axle nut?
Last option: stop at a diesel mechanic shop. 300 lb-ft is finger tight for them.
Old 09-19-2021, 06:17 AM
Curious what is this bolt on?
Maybe you said above but didn't see it.
Old 09-19-2021, 06:31 AM
john70t's Avatar
errrr...use the same effort and tools but in the opposite direction?
I'm guessing 305 is about 250 plus a 1/16th-1/8th turn.
Old 09-19-2021, 06:57 AM
A930Rocket's Avatar
BMW 330ci crankshaft bolt.
In replacing the lifters on the car, I decided to go ahead and change the timing chains, ramps, etc.
Old 09-19-2021, 07:15 AM
I like how it's 305, not 300, not 350, 305. It would have been even better if the spec said "307.3"
Old 09-19-2021, 07:27 AM
john70t's Avatar
German engineering.
Anything out of .005% tolerances results in the front wheels bouncing a foot off the ground at highway speeds.
Old 09-19-2021, 08:25 AM
415 Nm
Old 09-19-2021, 10:50 AM
Information Junky
island911's Avatar
This ^
A 200 lb person stand on a 1.5-ft bar will do it too.
Disclaimer: the above was 2’ worth.
Old 09-19-2021, 12:20 PM
Are you 305 lbs? That makes the math easy...
Old 09-19-2021, 03:35 PM
Information Junky
island911's Avatar
LOL
nicely played.
Old 09-19-2021, 03:54 PM
