Quickjack seems... not right.
I picked up a Quickjack 5000SLX from Costco not too long ago. Finally had a chance to use it today, now that the 911 is out of the garage. I can't seem to find a good lift points with the 911 (85), so I tried with the 968, since there are dedicated lift points.
One one frame, my lock cam is gouged and binds up on the lock when lowering. On each gouged spot. (Tried filing it smooth...)
On the other frame, the locking arm rises out of the channel and skips over the frame if the car's weight is on it. That frame also wants to sink under the weight of the car.
Add those two together, and you have a problem like I did, with the car sitting at a severe angle and one side sunk and the other side bound up.
Everything is bled.
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 12-11-2021, 07:31 PM
Bland
unclebilly's Avatar
Take it back to Costco and get another one.
Old 12-11-2021, 07:44 PM
Tempting. It took about three weeks to get, since they don't carry them in store around here. Before I do that, I'll contact Quickjack, since I'd be losing out on the lowered price that Costco had at the time if I re-order.
Old 12-11-2021, 08:44 PM
Cant see what's causing the arm to not ride in the channel. But it looks to be not set up right.
Old 12-11-2021, 10:02 PM
You do not have permissi
john70t's Avatar
Take it back to Costco. Our host sells these.
Not sure how the lift works, but it look like a hollow steel rivet acts as the pivot point for that piece. Yikes.
Nothing at all looks factory lubricated.
Check for all smooth operation when not under load, first, before any weight is lifted.
(i.e. no expensive car frame is above it)
Old 12-11-2021, 10:57 PM
Information Junky
island911's Avatar
Yep. Obviously binding up higher, at or near the link pivot.
Old 12-11-2021, 11:03 PM
Yeah, even with no load, the locking cam binds up. And you're right, the pivot on the cam is a hollow rivet.
As much as I love our host, their price wasn't remotely competitive with Costco. And the Costco return policy makes in a no-brainer.
Old 12-12-2021, 08:24 AM
cantdrv55's Avatar
I bought the 7000 lb model from Costco last month and haven’t unpacked it yet. I better give it a try ASAP.
Old 12-12-2021, 06:21 PM
I purchased a 5000SLX from Costco last year and it's working great. I would take yours back based on the look of the cam alone.
Present: 1984 928S/Indischrot, 1994 968/Polar Silver
Past: 1979 911SC Targa/Petrol Blue
Old 12-12-2021, 07:30 PM
Update:
Quickjack support has had me remove, clean, and blow out three different valves, swap the hose fitting on the power unit, try each hose on each fitting, and flush the unit by holding both up and down buttons for 10 seconds.
Problem still persists. Won't even hold my own weight without sinking. And as one side sinks, the other side rises. Hadn't notices that before, but that doesn't seem right unless a control unit valve is borked.
They're sending me the following:
1 safety arm assembly
1 double threaded rod
2 nuts
1 cam
1 spring pin
1 male power unit fitting (one of those fitting had a center "plunger" that seems...sticky.)
Old 12-16-2021, 11:11 AM
Now that I have finally had time to test this stupid thing again, I'm convinced that one of these frames is tweaked.
A few things have happened since my last post.
Quickjack sent me new hydraulic fittings made by a company called SABE manufacturing. They don't work with the fitting that came with the unit - they will NOT snap together, no matter what. Now I have a mish-mash of hydraulic fitting that don't want to cooperate, some that work, and some whose center "plungers" stick open, which Quickjack says isn't right. In order to test it today, I replaced a power unit fitting with the original that was sticking open.
They sent the new cam to replace the gouged cam. That worked, and that frame no longer binds while lowering.
They sent a new locking arm to replace the locking arm that skipped out of the channel, on the other frame. Along with the long bolt to mount it. The bolt they sent? It was visibly bent... and much different from the original bolt.
They advised using the original bolt with the new arm. Ok, cool.
They sent a new hose with two fittings... that don't fit the fittings they're supposed to snap into. Because they're SABE.
The new arm has the same problem. It skips out of the channel and want to ride of the frame itself, the cam drops, and won't lock. Even manually lifting the cam, the arm doesn't want to drop into place unless it's forced. This frame is tweaked somehow. It has to be.
Due to my frustration and the issues I've had, they also sent a "gift" -- a complimentary cross-beam adapter. Upon delivery, the box was split open on both ends. And parts were missing...
I'm about done with this thing.
To my surprise, they also sent a JackPack lithium jumper pack/air compressor unit. Wasn't expecting that, but I'm expecting it to blow up the first time it's used.
Old 02-13-2022, 06:10 PM
Have you tested it yet? And if so, how did it work for you?
Old 02-14-2022, 03:10 PM
Pack it up and take it back to Costco tonight. Seems like this one just isn't worth the hassle.
Then get one of these: https://standardus.com/rotary-pad-style-auto-lift-6-000lbs-capacity-mid-rise-portable-revolution-r-rmr6.html
1982 911 Targa, 3.0L ROW with Webers
Old 02-14-2022, 04:34 PM
Control Group
Tobra's Avatar
Return it
Old 02-14-2022, 04:53 PM
Still here
pmax's Avatar
What's the worst case scenario of a car lift not working right ?
Old 02-14-2022, 04:56 PM
cantdrv55's Avatar
I was shorted two couplers so QuickJack is sending them to me. Will test it once I get the missing parts.
Old 02-14-2022, 10:09 PM
and... how well are the other parts engineered and tested? If I was Costco I'd send these guys packing.
Sold: 1989 3.2 coupe, 112k miles
Old 02-15-2022, 09:18 AM
Zeke's Avatar
Certainly a valuable heads up here. Costco is good about taking things back even if the item declares, "Do no return to retail store, contact us directly for warrantee assistance, etc."
(my words to the best of my recollection.)
Once something is cobbled up, it's just no good. Like a floor jack that tipped over. After that they have an affinity to tip.
Old 02-15-2022, 10:00 AM
SCadaddle's Avatar
Yeah, I agree with this. I imagine someone with the manufacturer who is very liable for their product has no idea what their subordinates are doing by sending you replacement parts for a product that was obviously defective right out of the box. I would have washed my hands of that particular device long ago.
Old 02-15-2022, 11:16 AM
Platinum Member
dad911's Avatar
Nevermind, my mind was on max jack, not quickjack.
Old 02-15-2022, 11:21 AM
