The Unsettler
stomachmonkey's Avatar
https://bimmercode.app/adapters/
If bimmercode supports em, they'll be pretty good
Cause they code bimmers with it, and well, it's the more fancy work you would do with an odb adapter
why is everybody talking about apps when the question is bout hardware?
Because the hardware is only as good as the software you use with it and there are bigger differences in the apps in terms of features than the hardware.
"I want my two dollars"
"Brandon Won"
Old 01-09-2022, 10:04 AM
Gon fix it with me hammer
svandamme's Avatar
Well, sure, but you without the good dongle you can't use the good soft, and the question was what is the good dongle.
This thread went like
Question "what is a good laptop"
First answer "use Red had Linux"
Second Answer "the laptop doesn't matter much , it's the OS that counts"
To be clear.. The dongles are not all the same, cause the cheaper ones have slow transfer speeds.
And they will not work with apps that code.. So no , they are not the same at all.
IF you want to do serious things with the software, you'll definately need a good one or you might actually mess up the the car if you do anything with coding.. I've seen a Bimmer get all out of whack from using a bad dongle.
so you have it reversed : The Software can only be as good, as the Dongle you use with it.
And you can delete software and get another app instead
you cannot simply buy a dongle and then 3 months later decide you'll just send it back and get another one. the one you buy you are stuck with, if it's no good, you'll have to spend more to get a new one.
And you might blame the softwares along the line if they don't work well over that cheap dongle you have.
So step 1 : get a good dongle , because there are chitty ones out there.
Stijn Vandamme
BIMDIESELBMW116D2019
Old 01-09-2022, 10:19 AM
svandamme's Avatar
To give you and idea :
Both bought on amazon
Top one is good, made in Germany
Bottom one will brick the software and you are off to the dealer to get the car reprogrammed
Top one has way higher transfer/sample rates, which is what you need for diagnostics as well.
Stijn Vandamme
Old 01-09-2022, 10:24 AM
David's Avatar
Originally Posted by rusnak View Post
I should also offer my own experience with adding a third radiator. I had an air bubble that caused scary high temperatures. I got an Airlift vacuum filler, and now no more air bubble.
/img]
I went through all that but I am a little suspect. I’ll get it plugged into a shop’s PIWIS to check it out.
Old 01-09-2022, 01:47 PM
