Platinum Member
Batteries - Should be simple, never is.
Battery in my skid steer would not take a charge. Intestate.
Pulled it out, which was a royal PIA. Put charger on it again, zero current. I walk away to get a meter, come back, and it's charging. Why would it not take a charge initially?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Information Junky
Paging Aurel ...
I think that some oxide layer may have needed breaking down.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Maybe put in a battery that isn't as vunerable to vibration/ breakage.
I would try an Interstate battery next time.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
He's must be thinking about the other thread - Unfortunate choice of executor
^^^ I missed that one. I don't think I could ever be an executor.
Chargers in the last decade or so are all micro processor controlled with a bunch of safety nannies to protect you from yourself. If it is one of these models it may have had to ponder life for a while and decide if it trusts your intentions of good over evil.
If it is one of those lovely 0ld fangled transformers in a box types, just had to depassivate the plates a bit.
84 930 07 Exige S |
My Land Rover independent mechanic and I had a discussion re: batteries last months when my wife's Interstate battery crapped out for the second time in 2 years. Yes, one new battery for each year. At $200ish each, I'm not laughing. Anyway, they sell Interstate and Continental batteries. He said that Interstate has been having issues and a lot of batteries dying prematurely in the last couple of years. It seems to be a trend these days.
Matthew - drove Nurburgring with wipers on and no rain 1969 911E SOLD ![]() 2002 996 Cabrio 1995 993 Carrera 4 SOLD 2004 Land Rover Discovery II G4 Edition (Sold )
^^^ Have you ever tried Intestate batteries?
Free minder
It could be that the electrodes were sulfated. Lead sulfate is insulating. Now, just because you could get the battery to charge doesn’t mean it will hold the charge…
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
IF this latest battery doesn't last maybe I will.
https://www.harborfreight.com/digital-automotive-battery-analyzer-66892.html
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
UnRegistered User
My fancy electronic charger will give a bad battery code when trying to revive some flat batteries. If I use the old school Century charger on it first on the highest amp setting and after an hour or two switch to the fancy electronic one I seem to get good results and the batteries seem to hold a charge well.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
canna change law physics
This was a nominal 48V system with eight 215 AH batteries. Someone switched the system to inverter battery mode and left it that way for a couple of weeks with nothing charging it.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Platinum Member
The 'computerized' fancy charger didn't think a battery was connected. The 40 YO sears charger is supposedly charging it.
I guess I'm lucky to have my 35 year old Schumacher charger that still works fine.
Timely thread, I need to replace the battery in the Cayenne and apparently there's a new battery called an AGM. Supposed to last longer than lead acid. Anyone know anything about these?
Tru6 Restoration & Design |
AGM batteries generally last longer than standard lead acid batteries. Because of their low self-discharge rate, AGM batteries also last longer than their flooded counterparts when not in use. A well-maintained AGM can last up to 7 years, while flooded batteries typically last around 3-5 years.Jul 6, 2021
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
https://www.thedrive.com/cars-101/36405/what-is-an-agm-battery#:~:text=An%20AGM%20battery%20is%20a%2012-volt%20car%20battery,%28or%20Material%29.%20How%20 Does%20an%20AGM%20Battery%20Work%3F
If fancy charger isn't charging or throws code on your half dead battery, hook up another good battery to it along with the one that needs charging. The charger will recognize the good battery and starts charging them both.
No more Optima for me. What a POS. I have had good luck with Exide AGM battery on my 4 runner. It lasted 7 years so far but its seems to be getting weak. I am sure it is made by one of the large battery mfgs? |
Almost Banned Once
I stopped messing with car batteries years ago. In good faith I bought a yellow top Optima battery but it failed in less than 12 months and the manufacturer wouldn't honour the warranty because I had a high powered stereo in my car.
![]() So now I only use "standard" batteries and replace them as needed. You could try adding rejuvenation etc. but IME it's best just to bite the bullet and buy a new one. I use this to test car batteries... If it fails the test it gets replaced. - Search for "Solar B47" on Google. ![]() and Kent's excellent video on how to use one.
- Peter |
