Friend of Warren
Paint cracking on my VW. What can I do to slow it down/stop it?
Car was painted by the previous owner. As you can see, I’ve got the paint cracking on the rear trunk/engine lid. I suspect that he applied too many layers of paint and the vibration of opening and closing the lid is causing the paint to crack. Any suggestions as to how this occurred and what I can do to try and slow down or stop any further cracking? Thanks! I really want to avoid having to repaint the engine lid as I’m not sure I can find an exact match to the paint. Plus it would be a pain in the butt to do so.
Kurt V No more Porsches, but a revolving number of motorcycles. |
I know of no way to fix that short of painting it.
In the interim, you might make sure it’s heavily waxed, to keep water infiltration from occurring. |
Yea, the paint is lifting off of whatevr is underneath. Likely just a bad paint job.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Nice car, but in the end, all that area will need to be sanded off and repainted. The only other solution I can think of would be a wrap.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Far from a paint or body expert, but from what it looks like there is either a old repair down there and the bondo or whatever is separating (not likely...) or that area wasn't completely and properly cleaned, primed, etc. before paint. |
Call it patina and live with it.
Or get a pro to match the paint. |
She's a beauty, Kurt! I'm no expert but seems like just being careful with any further jarring would help the most. Waxing those areas also is a good tip from Java. Good luck!
Old dog....new tricks..... |
weekend wOrrier
Looks like body filler is lifting off the metal and taking the paint with it.
Wonder if some super glue down in the cracks would buy you some time .
No left turn un stoned |
that's a cool car!!
no clue on the temp fix. to me it seems like "game over". water can get in. and that is never a good thing. seems like that is either gonna propagate rust, or if you are in a freeze thaw area, it will simple get under there and the cracks will spread.
poof! gone |
Friend of Warren
Thanks for all the suggestions. I’m wondering if maybe I should just put a clear bra over it for now. That would at least keep the moisture out and perhaps slow down the cracking.
In the long run, it’s just easier to paint it. You can have some test panels sprayed before you start the repair, to the nail the color match.
Caulk it
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
weekend wOrrier
I SOOOO want to take a large disc sander to that thing. Nice coarse grit, go right through to metal and leave a nice layer of bondo dust all over the garage and the rest of the car.
![]() Do as Java says- practice mix to get the color right, then strip that off and clean up whatever is underneath. |
Flex Seal perhaps???
"A little nonsense now and then is relished by the wisest men." Wonka |
I laughed, but this is probably the only answer.
![]() Clear caulk.
poof! gone |
Hell Belcho
There's bondo under that paint. Sorry to say..
Saved by the buoyancy of citrus. |
if it's only on the deck lid
a few hundred bucks and its fixed |
This.
My TR is almost that color. One of the fenders cracked the same - after an ungodly expensive bare metal respray. Wasn’t bondo - too heavy on the paint. The only fix was to take it back and redo. You’ll never be happy until it’s fixed... |
