Friend of Warren
Paint cracking on my VW. What can I do to slow it down/stop it?
Car was painted by the previous owner. As you can see, I’ve got the paint cracking on the rear trunk/engine lid. I suspect that he applied too many layers of paint and the vibration of opening and closing the lid is causing the paint to crack. Any suggestions as to how this occurred and what I can do to try and slow down or stop any further cracking? Thanks! I really want to avoid having to repaint the engine lid as I’m not sure I can find an exact match to the paint. Plus it would be a pain in the butt to do so.
Kurt V
Old 01-13-2022, 08:57 AM
I know of no way to fix that short of painting it.
In the interim, you might make sure it’s heavily waxed, to keep water infiltration from occurring.
Old 01-13-2022, 09:02 AM
Yea, the paint is lifting off of whatevr is underneath. Likely just a bad paint job.
Old 01-13-2022, 09:14 AM
Send a message via AIM to fintstone
Nice car, but in the end, all that area will need to be sanded off and repainted. The only other solution I can think of would be a wrap.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 01-13-2022, 09:17 AM
id10t's Avatar
I wouldn't consider a wrap as a fix - until the area is sanded down and reprimed at least.
Far from a paint or body expert, but from what it looks like there is either a old repair down there and the bondo or whatever is separating (not likely...) or that area wasn't completely and properly cleaned, primed, etc. before paint.
Old 01-13-2022, 09:27 AM
Bill Douglas's Avatar
Call it patina and live with it.
Or get a pro to match the paint.
Old 01-13-2022, 09:31 AM
She's a beauty, Kurt! I'm no expert but seems like just being careful with any further jarring would help the most. Waxing those areas also is a good tip from Java. Good luck!
Old 01-13-2022, 09:42 AM
Data Farmer
Looks like body filler is lifting off the metal and taking the paint with it.
Old 01-13-2022, 10:39 AM
No, me either. Yes, poor prep. Many heavy coats of lacquer would sometime do that as well.
Old 01-13-2022, 10:49 AM
fastfredracing's Avatar
Wonder if some super glue down in the cracks would buy you some time .
No left turn un stoned
Old 01-13-2022, 11:45 AM
vash's Avatar
that's a cool car!!
no clue on the temp fix. to me it seems like "game over". water can get in. and that is never a good thing.
seems like that is either gonna propagate rust, or if you are in a freeze thaw area, it will simple get under there and the cracks will spread.
poof! gone
Old 01-13-2022, 11:52 AM
Friend of Warren
Thanks for all the suggestions. I’m wondering if maybe I should just put a clear bra over it for now. That would at least keep the moisture out and perhaps slow down the cracking.
Kurt V
Old 01-13-2022, 11:58 AM
In the long run, it’s just easier to paint it. You can have some test panels sprayed before you start the repair, to the nail the color match.
Old 01-13-2022, 12:09 PM
Caulk it
Old 01-13-2022, 12:13 PM
Data Farmer
I SOOOO want to take a large disc sander to that thing. Nice coarse grit, go right through to metal and leave a nice layer of bondo dust all over the garage and the rest of the car.
Do as Java says- practice mix to get the color right, then strip that off and clean up whatever is underneath.
Old 01-13-2022, 12:18 PM
HobieMarty's Avatar
Flex Seal perhaps???
Wonka
Old 01-13-2022, 07:06 PM
vash's Avatar
Caulk it
I laughed, but this is probably the only answer.
Clear caulk.
poof! gone
Old 01-13-2022, 07:07 PM
Hell Belcho
Nostril Cheese's Avatar
There's bondo under that paint. Sorry to say..
Old 01-13-2022, 09:58 PM
if it's only on the deck lid
a few hundred bucks and its fixed
Old 01-13-2022, 11:59 PM
This.
My TR is almost that color. One of the fenders cracked the same - after an ungodly expensive bare metal respray. Wasn’t bondo - too heavy on the paint.
The only fix was to take it back and redo. You’ll never be happy until it’s fixed...
Old 01-14-2022, 04:42 AM
