Evil Genius
Life is a big ocean to swim in. Wag more, bark less.
I plugged in the cord and height from my tracing into the calculator; it wouldn’t accept .10 in the height, cord was 1.33, so I base 10 the thing and came up with a radius of 7.21 and doubled for a diameter of 14.42” does my math track, or do I need to correct anything because I multiplied by 10? Here are a couple pictures. ![]()
Rutager West 1977 911S Targa Chocolate Brown |
A couple of you recommended running a trammel on a router, but as you can see from the picture above, it would take a custom bit to make the shape, but a chisel on a lathe could make the shape pretty easily; even with my basic skill level.
Thanks for all the suggestions, that’s why we bring all our toughest quandaries to the board!
Let’s try this again! Watching the video posted, I got out my calculator and punched in my numbers and came up with 4.5”. I set my compass to 2.25” Drew a circle and bingo, matches up nicely. Looks like the lathe is an option.
Probably fairly obvious by now, but I have always struggled with math and really need to prove it empirically to trust my answer.
Only thing I know about lathes is watching some wood turning stuff on youtube because it looked cool and was in my suggestion list...
How do you make a shape like that with a lathe? Start with a 5x5 block of wood and shave it away until you have a 4.5" circle? You'd still need to slice off a wafer and then cut the shape out (looks like you could get 4 per wafer) and then do the other required shaping on them... or is that the plan? |
The Unsettler
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
