Brew Master
The Dewalt will eat that thing for lunch! Seriously, if you haven't watched the comparison videos I posted in my thread, they're worth the watch. The Dewalt is for real. I went into it a skeptic and after using for the first time came away a believer. The saw really impressed me. I plan to take it to my hunting property to clean up some downed trees in the near future. I'll let you know how it does when I get the chance to go up and use it.
Nick Last edited by cabmandone; 03-28-2022 at 09:50 AM.. |
i have an echo and a craftsman.
i had a craftsman that lasted a loooong time even with abuse. they also come with a case. problem with new saws is both of mine came with some california BS on it. the other problem is is does not matter what saw yo buy if you dont run it it WILL NOT run after a while. speaking of that i need to get them out and run them
Brew Master
Come up to Ohio. I've got plenty of wood to cut at the hunting property. Dead Ash trees everywhere!
Nick |
My wife went out in the common green area of our neighborhood association, and brought back a limb that was 2.5 inches in diameter, and 6 feet long and I needed to cut it to fit in the trash can. She had cut off all the little stems and side branches with the electric sears I got her for her birthday, but she left the 6 foot tall branch sticking out of the trash can for me to deal with. It was going to require a saw of some sort to deal with. I have an electric chain saw, and it would make short work of it. But it is still a bit of work to get all set up. I grabbed a tree saw that was Glen powered. I had it cut in half in under 10 seconds. Sometimes for very small projects the manual saw is faster and easier than anything else. That tree saw hangs in the storage building above the chain saw.
No doubt, if I had multiple cuts to do, the electric saw would have been used. We have a wood burning fireplace, but the wife does not like the mess or the work to keep up with a pile of wood. It has only been used once, when the power was out for a few hours. About the time the fire was going enough to make heat the power came back on.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I see you
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
First thing ya do with anything is remove those damn "spark arrestor" screens... they rob power, and as the carbon builds up, it gets even worse. And if you remove the 15 warning stickers it makes the saws lighter too
Brew Master
But then how will you know that you're not supposed to put the sawblade on your leg while the engine is running and pull the throttle?
Nick |
I see you
How many operating hours between fluid changes? ;-)
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." Last edited by flatbutt; 03-28-2022 at 02:38 PM.. |
I think it depends on your warning fluid specification. If you're running something that you can pick up at your FNEC (friendly neighborhood emergency clinic) then it's probably not a big deal to change more frequently. But if you're running some sort of weird European proprietary fluid, then you may want to stretch your change intervals as long as possible.
Brew Master
Nick |
Brew Master
Here's one I don't know if I posted on my thread. I know what you're saying about cost. It's definitely not a less expensive option. But two batteries will cut a lot of wood. Plus it gives you time for a nap while the batteries are charging!
https://youtu.be/S4ktxZlhb-Y
Nick |
Now in 993 land ...
The electric stuff is probably fine for home owner use. My concern would be aging of the batteries both over decades electrochemically but also being outdated with better stuff soon! It seems there is always a better battery around the corner.
A good quality gas saw will last you the rest of your life and will sell for more than what you paid for it at your estate sale. I was in a similar situation about 10 years back and bought a Stihl. I buy the premixed gas from Stihl or the hardware store and even in the CA heat in the garage, it never needed anything, even sitting for sometimes 2 years at a time. A couple cranks and it's on! The premix is sold in a gallon and yes, probably about $25 but with light use it will last you several years. If you ever need to run a lot of gas, by all means mix yourself with the ethanol stuff, just make sure the last couple fills are back on the premix that has no ethanol. This is the model I bought. I wanted something big enough for firewood and when hunting. I often go late season and there may be deadfalls blocking you in. Its also happened that jokers drop a tree in the road for you to cause you trouble going home, if they don't like you showing up in "their spot" on public land. We have big trees here, so needed something that can deal with a few feet diameter, even if it will take a while. Here is a nice review except for this guy being extremely unsafe with it. Surprised he still has all his digits and limbs. Have fun! |
^^^^ G ..... You are spot on. Though I have an older MS250, and prefer it over the newer versions... one will not regret purchasing a "real" saw meant to last a lifetime for most homeowners. Will the battery powered stuff last and perform for 20+ years.... who knows? For around $350 a 45cc Stihl with a 16" bar is just a great saw for most folks to purchase and keep forever. Battery powered stuff has it's place .... just not my place
Occasional use for me on one acre is the EGO 56 volt 40 cc equivalent 16" electric chain saw.
It is so easy to operate and very powerful. I like it.
67 396 corvette coupe. Sold 66 351 AC Cobra kit. Sold 99 996 man coupe 2001 911 Turbo man coupe |
