Arizona_928's Avatar
Stuck oil filter.
Saw this on the ole reddit. Enjoy!
dolor et pavor
Copyright
Old 03-27-2022, 06:52 PM
Hate it when that happens.
206 637 4071
Old 03-27-2022, 07:04 PM
note the direction of the buckle.
dolor et pavor
Copyright
Old 03-27-2022, 07:07 PM
craigster59's Avatar
Bang a large Phillips screwdriver through it and crank clockwise, that'll get it off.....
Old 03-27-2022, 08:31 PM
D idn't E arn I t
RANDY P's Avatar
^^^^ what I do.
rjp
AOC/Hogg 2028
Old 03-27-2022, 08:58 PM
You're a menice to society!
dolor et pavor
Copyright
Old 03-27-2022, 09:22 PM
Bill Douglas's Avatar
Unscrew is anticlockwise.
Old 03-27-2022, 10:26 PM
pwd72s's Avatar
Sure looks like clockwise was used.
Old 03-27-2022, 10:44 PM
rfuerst911sc's Avatar
Righty tighty lefty loosey 😁
Old 03-28-2022, 03:25 AM
That usually works, but many years ago (35), I had that just result in the bottom of the filter ripping off. I ended up having to use a cold chisel or regular screwdriver to pound the flange at an angle to get the rest of the filter off. It was the result of taking a car to an oil change place.
Old 03-28-2022, 04:25 AM
Yer a bad man .... a very, very bad man !
First time removing the filter after acquiring my 911... that sucker was not budging. First with the proper "thingy" that fits over the end of the filter, then I bought a filter "strap wrench", then I resorted to a big screw driver punched through the filter.... that just mangled the filter, but still stuck .... ALL while turning counter-clockwise, and I just had a mangled mess on my hands.
I then bought a pair of "Big Azz" channel lock pliers (yes, that name is stamped on them) and got that sucker off
Old 03-28-2022, 04:32 AM
Almost Banned Once
sc_rufctr's Avatar
I have a small collection of strap tools and LARGE sockets so I rarely have an issue but the screw driver through the side trick has saved me a few times. The newer screw on plastic caps work well but it's really easy to scar them.
- Peter
Fleabit peanut monkey
Bob Kontak's Avatar
Tijuana Speed Wrench
+1
Screwdriver trick has failed on me more than it has worked.
1981 911SC Targa
Old 03-28-2022, 04:44 AM
Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
Probably went over his oil change limit and it cooked on, that or the dummy buggerd it up and tightned it instead of loosened it..
Getting old sucks, bring back the good old days, this new stuff is for the birds..
Old 03-28-2022, 05:28 AM
Preferred pronoun:Maestro
Norm K's Avatar
As long as there's room to rotate the spear this is a quick and clean method.
Well, it's quick anyway ...
_
When in doubt, use overwhelming force.
Old 03-28-2022, 05:29 AM
_
I challenge anyone to use a screwdriver and remove a stuck filter by turning it clockwise! Unless you have left-handed clocks
Old 03-28-2022, 05:46 AM
You do not have permissi
john70t's Avatar
It works on bicycle cranks and some truck lugs. Turns it brand new.
Old 03-28-2022, 06:01 AM
After 30 years 375,000 mile on my El Camino I have done a lot of oil changes. Only once have I had a problem getting the filter off. It turns out the dummy that put the last filter on (me) did not inspect the old filter very well. It left the rubber gasket behind on the engine. The new filter just added in a second gasket. For whatever reason the two gaskets bonded and made a crazy seal. I tried my oil filter wrench, and two different strap wrenches. I finally had to get a chain wrench that really bit down on the filter and a long pull handle to get it to let go. When I got it off, I saw two rubber gaskets and really cussed at the dumb MF that did not check the engine before putting on the new filter. Now I double check it is just a film of oil on the engine where the filter screws on. And it sure gets a nice coating of oil on the rubber gasket.
For my wife's Macan, the filter is a cartridge. The housing has a 32 mm nut on top. It has two paint parks, on on the housing top, and one on the bottom. Tighten to there, and it simply stops. Very easy to do.
Old 03-28-2022, 06:10 AM
Channel Lock actually makes a filter wrench/pliers. They work great.
Old 03-28-2022, 07:09 AM
(the shotguns)
berettafan's Avatar
Just taught my son that trick last week. Did his first oil change and that beech wasn't moving and my filter socket didn't fit.
Old 03-28-2022, 07:15 AM
