Targa, Panamera Turbo
High Altitudes Have O2!**
Many believe that there are less oxygen levels at high temperatures which makes mountain climbing difficult. That is actually not the case. The reason why it is difficult to breathe at high altitude has to do with a reduction*of pressure. Our respiratory systems require external pressure*(partial pressure) to work.
Here are a couple of cool sites to check out: The Composition of Earth’s Atmosphere With Elevation | MrReid.org https://www.irunfar.com/into-thin-air-the-science-of-altitude-acclimation
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
Information Junky
Cool stuff.
I would have put the height on the Y-axis, but still good. But where is the massive amounts of man-made CO2 ?
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
I see you
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
When I worked on the Sierras and came home after 3 to 4 months living, hiking, & climbing at 10 - 13K feet, I noticed how easy aerobic activity was at sea level. i once went to the doctor after coming out of the mountains and gave a blood sample. The doctor commented my red blood count was sky high and asked if I might have an idea of the reason. He understood after I explained I'd been living at a high altitude.
Marv Evans '69 911E |
Yep, same percentages of gases as at sea level...just less volume because of less pressure. "Thin air" is an accurate term.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Living in Boulder for a while I certainly noticed this. But, when I came back to Willamette Valley Oregon, I could run for MILES!
At least to the OP...
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Gon fix it with me hammer
I would think if there is less pressure; there will be less O2 per cubic meter of air.
eg the level of O2 is lower per given volume The level of other molecules will also be lower.. the ratio should be similar but you might get a slightly different ratio because lighter molecules will be more prevalent then heavier molecules... but that would not be to a degree it really matters for breathing Also, because pressure is lower, the O2 exchange in the lungs will be less effective. Think air cooled engines... Air cooling works less effective then water cooling because in essence there are less molecules going past the heat exchanger surfaces. The fan increases that pressure. Also the oil pump increases the oil pressure at the oil cooler higher pressure means more atoms at the exchanger Same with lungs. In any case, I would still state that its harder to breathe because there is less O2 up there... That is not an incorrect statement At least not per volume.. Total O2 up there? wel the circular diameter of the athmosphere is much bigger so maybe total O2 for the entire altitude is similar.. vs at the ground.. it's just spread out more? But for breathing that is pretty much irrelevant.
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 Last edited by svandamme; 05-24-2022 at 12:22 AM.. |
less pressure results in a less
dense atmosphere so less oxygen by volume and less oxygen contained in each breath what I find surprising is that we are having a conversation to clarify something I thought was so obvious |
Yea, less oxygen, less nitrogen, less carbon dioxide and just less air up high. Ratios may be the same, but just of them. Duh.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I do think that at least part of the issue is that each lung full of air will contain less oxygen. But the partial pressure of oxygen in the air vs blood stream will be different than at or near sea level. Therefore, it's possible that our lungs/blood will have a much harder time taking in what oxygen IS in the lung full of air. Partial pressure relates to the pressures of the constituent gases in a mixture and how that amount of gas would relate to the overall volume of the mixture, IIRC. It's the reason that carbonated beverages go flat when they are opened, and why when they are really cold, they lose that carbonation more slowly than when they are warm. I assume opening a soda or beer at mountaintop atmospheric conditions would probably be a lot more exciting than opening one at sea level. I hadn't previously read this article because it was next to the image, and I assumed it was part of the link to the image or something. Quote:
On a related note, sherpas are genetically different and adapted to functioning at high altitudes. I read about this a few years back and thought that it was fascinating. https://www.bbc.com/news/science-environment-40006803 Quote:
