Author of "101 Projects"
Wayne 962's Avatar
Need some suggestions on replacing broken PVC pipe...
Hi all. Here's the story. Broken PVC pipe under the paver stones. This is a return line to the pool (sends water back to the pool from the filter / heater equipment). Our area has a lot of land movement, and the pipe broke at the 45-degree joint. This is the 2nd 45-degree joint like this that has broken. I had the other one repaired by someone else for $750 last year, which I thought was really expensive at the time. This time, they wanted $950. Seems like about three hours of work. Could be cheaper to hire my attorney to repair the pipe, but that's a discussion for the politics OT forum.
So, I can cut the pipe back and replace a fitting, but the 45-degree bend makes "traditional" repair solutions a bit unrealistic. Since this is a pressure-side pipe, I was thinking of putting in a flexible coupling here - like FlexPVC or even some type of heater hose. I'm not sure how durable that would be underground. I was also thinking of putting a little box around the connection with some wood, so if I have to reach it again, I don't have to dig too far underground.
I'm leaning towards cutting off the fitting (already started to chip away at it), and then attaching some of that FlexPVC to perform the repair, and also to maintain some flexibility in the pipe. I'm hoping there are no more 45-degree bends like these along this pipe - I'm actually not sure why they were installed there to begin with.
Thanks in advance for any advice!
-Wayne
Old 11-07-2022, 12:44 PM
I had a very similar break (in a 45º underground) earlier this summer.
(and a corresponding thread)
Best broken underground PVC pipe fix?
The solution that the plumber used was to use 4x 90º in a vertical "bridge". Since those 90s can be rotated you can get whatever angle you need out of them.
Cut out the 45, add 90s and short vertical pieces, then 2 more 90s and a horizontal piece of the correct length to connect it all together. It also gives some flex.
WHat a huge pain in the rear to have your break right there with all of the other stuff in the ground.
Also, we have mostly clay here. WHen we are dry, we get a lot of movement. We had a very dry summer and ended up with 3 broken pipes because of it. The plumber said " when you fill the hole in around that fix, use sand/play sand. The sand will allow more movement/flex and be less likely to break again. Seems reasonable to me so that's what I did.
Old 11-07-2022, 12:56 PM
That looks like a pretty nice solution, Steve.
Is it possible to also use some flex PVC on the 'top' piece of the fix?
Wayne, you should be thankful it's under the pavers and not buried in concrete like my brother's pipe problem was. He decided to just cap off the bad section of pipe rather than bust up his new concrete.
Scott
'78 SC mit Sportomatic - Sold
Old 11-07-2022, 01:11 PM
I don't see why you couldn't use flex PVC.
In all 3 of the breaks that we've had this year, they have been in the very middle of a coupling of some sort, 1x coupling, 1x 45º, and 1x 90º. I think the couplings are stiffer and more brittle, but with a flexible PVC, the coupling may not experience enough stress to break.
Old 11-07-2022, 01:18 PM
What I love about this solution is that by going vertical with the 90º allows you rotate them to get whatever angle you need.
Old 11-07-2022, 04:22 PM
Platinum Member
dad911's Avatar
Is that 1-1/2 or 2"?
It's pretty common to use flexible PVC underground on pool lines. That's what I would do.
Use the good glue, blue can.
So you took off the deck and restarted the pool?
Old 11-07-2022, 04:43 PM
Wayne 962's Avatar
Not an accident! I vetoed all concrete because I anticipated this happening in the future...
-Wayne
Old 11-07-2022, 04:47 PM
Wayne 962's Avatar
I think it's 1.25" - seems like it from the outside diameter.
I just refilled the pool, but I can't restart it with the connection disconnected? I can, I think, manually configure the valves so that water is drawn from the pool and then sent back through the hottub just to keep the filter running. I was going to look into that tonight...
-Wayne
Old 11-07-2022, 04:49 PM
A930Rocket's Avatar
I am wondering why it broke? I presume driving over it, push down on the upper pipe, putting pressure on the lower pipe, breaking it. By doing the repair below, you can get some separation between the two pipes.
Get a pair of PVC pipe cutters, primer, glue, (4) 90° and a straight section you can buy in 2 foot lengths. You spend more time going to Lowe’s then you will fixing it.
Old 11-07-2022, 05:43 PM
In my case it was just ground movement due to drought. We had something similar occur in 3 different areas of the yard. Once it was a coupling between two pieces of straight pipe. I had walked over the area 1000 times (and cars and mowers had driven over it) in the past 2 years, but in Aug, I walked over the area. The first time was the 45 that is at the corner of the house. The third time was at the top of the well-head where the well comes up out of the ground and then there are 2 90s for it to go back down into the ground before it goes to the "pump house" where the expansion tank and pressure valve are.
Old 11-07-2022, 05:58 PM
I concour with Steve's suggestion, Wayne.
You need to bring both pipe ends straight up - and then reconnect them above those other pipes.
You should not need any flex pipe.
You should have enough "flex' already with standard PVC pipe. Especially if you bring the two ends up high enough.
I'm thinking a sawzall would be the easiest way to cut out the old 45. Make sure everything is dry before gluing. Get the fittings in all the way - the glue will act as a lubricant. Let the 90's/ells set up for at least 15-30 minutes before proceeding with the 2 vertical pipes. Once those are in - again - let it set up for a bit before the next step.
Then "dry fit" the next steps before gluing. One 90/ell on each pipe end 'facing' each other. Then measure and cut the top pipe. Then glue in one 90/ell, glue in the pipe. Test dry-fit with the other 90/ell. When satisfied finish the last fitting.
Hope this all makes sense.
Remember with this method you will no longer need a 45. Just pivot the top (2) 90's/ells so they face each other and you'll have it.
As far PVC thickness - I would go ahead with regular thin wall....but you could also use schedule 40 (thicker). That part is up to you.
Also - make sure when you backfill you are very careful to add little at a time and use your hose end with water running to wash/jet the backfill in as you work. This will help eliminate any air pockets.
Good luck!
Old 11-07-2022, 06:15 PM
BTW...that repair quote of $950 is absurd.....
Old 11-07-2022, 06:17 PM
Wayne 962's Avatar
I wonder if this thing would work okay:
https://www.amazon.com/Fernco-QwikFlex-Flexible-Coupling-Connections/dp/B09LMNYPS2/ref=asc_df_B09LMNYPS2/?tag=hyprod-20&linkCode=df0&hvadid=563592098316&hvpos=&hvnetw=g&hvrand=3586340397325456716&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9031046&hvtargid=pla-1600821013400&psc=1#customerReviews
-Wayne
Old 11-07-2022, 06:30 PM
Danimal16's Avatar
Wayne, I have recently been chasing all types of PVC breaks in an irrigation system.
Steve's suggestion is the way to go. Minimum schedule 40 repairs, the thin wall will become brittle and crack along the pipe. To prevent that from happening, use either a sawzal or a multitool. PVC cutters could cause the pipe to split longitudinally.
One thing and it is important, trench bedding. The original install with pipes crossing as in your case was probably caused by the upper pipe pushing down on the lower. Pipes should NEVER rest on one another, ever. That said, bed the repair with sand. Sand will fill any shadows under the lower pipe and mitigate any flexing.
Good luck with the repair.
Dan
Old 11-07-2022, 06:47 PM
Bland
unclebilly's Avatar
Cut it out a foot or so back, make up a new connection and install them with either a glued coupling on one end and a Fernco on the other or a Fernco coupling on both ends. The nice thing about Fernco couplings is that they are rubber so flexible.
https://www.fernco.com/
Old 11-07-2022, 07:25 PM
Bland
unclebilly's Avatar
Saw this after my reply. It will probably be ok. This is what Fernco has built a business around, solving these types of problems.
Old 11-07-2022, 07:27 PM
Danimal16's Avatar
Wayne,
I take it that this is a pressure line? If so the fernco line and couplings will not work as they are for non-pressure repairs, see ASTM-D5926 as well as ASTM-C 1173. Also, any flexible coupling must not be allowed to flex to the point that it causes axial loads at the point of connection.
Steve's repair is what I have been using with great success, it is straightforward, cheap and repeatable.
Dan
Old 11-07-2022, 07:44 PM
Wayne 962's Avatar
It broke because the ground is moving quite a bit. When I say "quite a bit", I mean like 3-6 inches in different spots. Pressure has been put on the coupler here, and it broke in the weak spot.
The line is not a "pressure line" per se - every line that has liquid that is transported through it has some level of pressure? This is a return line to the pool, so it is attached to a pump and that flows to three inlets into the pool. Low pressure as there is no back force placed on the flow - if one of the pipes back to the pool gets clogged or plugged (not sure how that would ever happen), then the water would simply flow out of the other two ports.
The only issue I see with the 90-degree pipe setup is trading two connections for eight connections. In my history - the more connections one has, the more likely to have problems in the future (sometimes).
What we have now is : pipe-to-45-degree-bend-to-pipe. We'd be replacing it with pipe-90-pipe-90-pipe-90-pipe-90-pipe - quite a bit more opportunity to make a mistake or something like that.
Food for thought. I'm going to order the flex hose on Amazon - it'll be here tomorrow - so that I can take a look at it (I can always return it).
Thx
-Wayne
Old 11-07-2022, 08:05 PM
Platinum Member
dad911's Avatar
If only there was a book... 101 Home repairs for the DIYer.... Chapter 6, Pools and Spas.
Not all Fernco fittings are rated for burial.
Old 11-07-2022, 08:19 PM
