Bland
^^^ totally agree.
It it was going to come up in one piece, it would have had to have been installed poorly to begin with. If it was installed poorly 20 years ago, in a high traffic area like an entrance, it would already be cracked. In my first house, my kitchen was retiled right before we bought it, within a month the tile started to crack. By the time I replaced it, the tile was cracked in all of the traffic areas. It was put down with small dabs of thin set and came up easily. Most of the tile in the non traffic areas came up without breaking. I don’t think you are dealing with this.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche Last edited by unclebilly; 11-24-2022 at 02:35 AM.. |
Bland
It’s probably cheaper to retile the entire kitchen than to pull up tile in the entrance, replace it, clean the tile from the entrance, then put the tile back down in the kitchen.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
I have done this, but it was challenging. I used muriatic acid to soften/remove the grout and was eventually able to get under them enough to free them. Some of the older materials comes up better than the newer ones. The tiles were much smaller than yours though.
Where I have needed to only save one or two, I was able to break/cut out some surrounding tiles and gradually chip away at the mortar underneath to save a few.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
How old is the house David? On the older houses, they hack up the joist and pour a bed of motar on it over 1x6. If its original to an older house (1920-30s) it will be a bear to take then out without damage. but then in those days, tiles were smaller
The tile is set on a slab and I only need about 10 of the 40 or so tiles intact. I'm going to remove the grout and use an oscillating multi-tool to get underneath each tile. I have nothing to lose, but thousands to save.
Wish me luck!
99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) |
Good luck. Let us know how it goes
Platinum Member
Freud DS0930CGX Carbide Grit Reciprocating Blade, 9" (Single)
I would try to get under it with a long masonry blade on a variable speed sawzall, like the above. The oscillating tool will only reach in an inch or so. Edit: herr_oberst beat me to the punch, while I was seeing if there was a blade available for sale......
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Try this:
There you go! Heat!
and a little patience. Totally makes sense, heat expands the tile breaking the bond |
Heat might work/help. I know my tiles pried up pretty easily by gently tapping a long putty knife under them after I removed the grout and soaked them pretty good in the muriatic acid. I mixed it a bit stronger and applied it much more heavily than I would normally use to clean tile before sealing and then wet it again really well with water when I mopped it up. I left the mild acid and then the water on for a while. Once the grout was gone (did not hold the water out), it leeched under the tiles and the mastic failed pretty easily. There was a lot of air under the tiles due to the troweling ridges.
"I" would only salvage 9 ....Good luck, take some pics, and keep us updated on the "score" .
I worked my butt off removing the 20+ year old tile. Out of all the tiles, I was only able to save 1! Because they were so large (17" x 17"), they always cracked about a third of the way up. When they were initially installed, the contractor did a great job. Live and learn!
Tough break! Merry Christmas!
