Senior Member
Riveting Question
These are photographs of a rivet which attaches an eyelet to a boot. As you can see, the rivet is not properly installed. The photos show both sides of the rivet. I have a rivet gun and a box of rivets, but they are unlike this one. So....I do not understand how this rivet works or how to fix it. Here is what I wonder:
Could it be as simple as pressing this rivet further using my bench vise? Simply compressing it to the point where the ends of the rivet are flush with the eyelet and the leather? Would I need to use a special jig, or can I simply put this in a press with flat business surfaces, such as a vise? ![]()
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
I'd try try vice technique or hydraulic press and use a washer on the inside part as a buffer. If that doesn't work, you can always drill it out & try buying a new one to press in. Maybe a grommet tool would work.
Marv Evans '69 911E |
Senior Member
I just used the simple vise method, and it worked. Thanks, Marv.
Great! Being on the inside if there are any irregularities, it could potentially be an irritant against your foot or ankle.
Evil Genius
Now try to do it 30 feet down in the puget sound while diving with tools.
Life is a big ocean to swim in. Wag more, bark less.
