Registered ConfUser
Deep freeze. Pipe question
Going to be below freezing for 3+ days here in Atlanta with early morning temps in the low teens.
Water turned off to all outside spigots and covered. Here’s my concern…house is on a slab so most plumbing (copper) runs through the attic. Two H2O tanks are also in the attic as are furnaces (heat pumps). Attic ceilings are not insulated, only floors. I’ve insulated the hot water pipes for obvious reasons but never thought to insulate the cold. Will make a trip to HD today to get more pipe insulation if they’re not already sold out and leave water dripping overnight. What’s my risk of attic pipes freezing? Heard horror stories from last years TX deep freeze. |
Here in Houston, I open my attic door to allow the warm air to get in and I also have an oscillating large electric space heater that I place adjacent to my pipes. Little things like that all help.
We're preparing for the same cold front starting today.
Ole Skool - wouldn't have it any other way |
It certainly would not hurt. I would do it.
I would insulate any waterline covered by batt/blown insulation as well. |
Registered ConfUser
There’s two lights up there and I was going to pick up some 100w incandescent bulbs and leave them on. Probably a drop in the ocean. I suppose adjacent furnace will be running 24/7 for a few days and most leak some warm air. Last edited by Chocaholic; 12-22-2022 at 05:25 AM.. |
Bland
That’s what I was going to suggest.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
I had a house on a slab here in Va for 3 years with late 90's Shell poly pipe in the attic-forget the name but its considered weak-and it was fine for a spell of a week in the teens a few years back-the air handlers in the attic kept it warm enough. If you're worried, let a faucet or two run very slowly at night.
However, did learn the hard way that mice get in in the cold and love to eat pex type pipe. Mine came in thru a external chase (think gutter alu pipe) that the freon lines ran in. Installers filled it with expanding foam, which the mice went right thru-should be filled with the stainless wool that rodent control guys use. Had numerous leaks in ceiling over Christmas week. Joy to the world.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
For the folks that are worried that you're going to have the same problem that we had in Texas 2 years ago, the main reason that so many folks had issues here was because the power was getting shut off so the heat wasn't running so the house wasn't warm. That wasn't the issue everywhere.
Redbeard or his parents had an issue, IIRC, because they had pipes in the exterior wall of the garage and the garage wasn't heated. I think there may have also been an issue where there were pipes in an exterior wall OUTSIDE of the insulation. Lots of folks had issues because there were pipes in the ceiling of the garage, again, no heat. I would think that as long as you're heating the house, that most of the pipes in the house should be good. Or maybe I'm wrong.
Been here a while
good call on letting the water drip from the faucet, running water won't freeze....
Also, when you shut off the outside faucets, it is best to leave the outside spigot open, if any water is still in the pipes, it is the expansion during freezing that causes the problems, so an open spigot will relieve the pressure.
looking for 1972 911t motor XR584, S/N 6121622 Last edited by blucille; 12-22-2022 at 06:17 AM.. |
Home of the Whopper
Heat trace thermostatically controlled to energize when temp below 35F.
Of course only works with electricity.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
Home of the Whopper
Image didn't work but something like this:
https://www.amazon.com/s?k=electric+heat+trace&adgrpid=76729917039&gclid=CjwKCAiAnZCdBhBmEiwA8nDQxVIFHw37cZfvlmizjsZs gpLpqoEhjWPpwaGCTDq7kynVdJ-bnCVuUxoCHh0QAvD_BwE&hvadid=409930806915&hvdev=m&hvlocphy=9060223&hvnetw=g&hvqmt=e&hvrand=12329390597211387762&hvtargid=kwd-300523798736&hydadcr=13567_11413433&tag=hydsma-20&ref=pd_sl_1iof4iqtjn_e
Home of the Whopper
And the HT goes under the insulation.
Be careful out there… |
Counterclockwise?
I don't think you'll have a problem. The heat from the house will get sucked up in to the attic.
It takes consistent cold for days before your pipes will freeze enough to burst them. If you are worried about it, let your taps drip.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
I'm not using that method now. I've made improvements and have a better understanding of what's going on.
Fleabit peanut monkey
Are you supposed to open the outside hand crank valve after shut off? Makes sense to lose any standing water inside.
1981 911SC Targa |
I've heard it recommended to add a way to use compressed air to blow the lines out.
Counterclockwise?
He's talking about 3 days around the freezing temp in a occupied home here.
Not going into an ice age
I’ve done the same. Finally did it right and installed heat tape on the pipes under the insulation. Sent from my iPhone using Tapatalk |
