LinkBack | Thread Tools |
Rating:
I don't understand the animus towards Baldwin. He swears he never pulled the trigger, but did pull the hammer back. They said the FBI never examined the gun for modifications, just pronounced that it couldn't go off without a trigger pull. They are now re-examining the gun for modifications.
I agree. CNN interviewed a movie set armorer who said, "Blanks and live ammo shouldn't be in the same zip code together, let alone on a movie set."
Edministrator
I read online that there is supposed to be an update today. The New York Post is reporting that the trigger was replaced. The idea of a repaired or modified gun amazes me:
https://nypost.com/2023/04/20/new-trigger-on-rust-prop-gun-before-fatal-shooting-caused-misfire-report/ Even if Baldwin didn't pull the trigger, there is lots of blame to go around. It seems like nobody took their job or responsibility seriously. I worry we may never know some of the key facts, such as why there was live ammunition on set.
Good post? Leave a tip! O - $1 O - $2 O - $3 |
Replacing the trigger wouldn't have mattered if he hadn't pulled it. Triggers don't pull themselves. I have replaced plenty of triggers in my guns and none have fired by themselves. They all require me to act before firing - dry or hot.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
What about the fact that the fbi destroyed the trigger making it inoperable...
dolor et pavor Copyright |
Shouldn't matter. Could be an 11 lbs pull, could be a 3 lbs pull. There's no such thing as a 0 lbs pull trigger. They all require a pull and, even if it malfunctioned, the hammer had to be thumbed back for it to fire. This stuff can only happen with human action.
Edministrator
Would it have been likely the FBI testing could have broken the original trigger, assuming the gun was in good shape? Or did it break because it was damaged/defective/aftermarket? It's disappointing that this far along we basically cannot rely on the testing that was done. I'd be curious to know how this modification/replacement trigger information is just now coming out.
Again, why does it even need to be tested? The gun did not load itself, did not aim itself, cock its hammer back by itself ...... Until they start making 0 lbs pull triggers and with AI that makes the gun fire itself, it doesn't matter what kind of trigger was in the gun or how well it functioned or malfunctioned.
Edministrator
It seems to matter to a lot of people whether Baldwin pulled the trigger or not. He acknowledges he pulled back the hammer, and when we released the hammer, the gun went off. Personally, I don't think it matters if he accidentally pulled the trigger. The safety protocols should have allowed for that, or him pointing the gun the wrong way. I think Baldwin's problems arise from accepting the gun from an unauthorized person and possibly if he had responsibility for the proper safety being performed by the crew.
If a lot of people understand that Baldwin may have not pulled the trigger, the hostility towards him might subside. Edit- all the facts will potentially help, especially if there's a criminal or civil trial.
Good post? Leave a tip! O - $1 O - $2 O - $3 Last edited by Steve Carlton; 04-21-2023 at 09:48 AM.. |
Counterclockwise?
With my single shot Cooey shotgun, if you pull the hammer back and let go of it before it clicks it will fire.
Can this handgun be the same?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs Last edited by 911 Rod; 04-21-2023 at 09:27 AM.. |
Of course. Lots of guns work that way, even some modern ones. It's not a flaw or a bug, it's a feature.
Counterclockwise?
So it could have gone off without him pulling the trigger.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
But not without his cocking the hammer back. It cannot fire without a human causing it to fire.
have to figure out another way to "get even" for the SNL skits. i guess.
The FBI determined, unequivocally, that this specific gun absolutely would not fire unless the trigger was pulled after the hammer was cocked, or held back as the hammer was cocked and then released. When they received the gun, it was in fine working order, unmodified, nothing broken, nothing repaired or replaced. So, please, put that one to bed - Alec Baldwin pulled the trigger, or he was holding it back as he cocked the hammer.
I have spent a lifetime with these revolvers, Single Action Colts and their "clones" (this one was such a "clone"). I've been handling and shooting them literally since I was six years old. Dozens of them have gone through my hands, with several having been permanently added to my modest collection. I have literally tens of thousands of rounds through these things, maybe over a hundred thousand. I'm here to tell you - there is absolutely no way on God's green Earth that one of these could possibly go off without either pulling the trigger after having cocked the hammer, or by holding the trigger back while cocking and subsequently releasing the hammer. Baldwin pulled, or was holding back the trigger. Period.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Edministrator
Investigators effectively conducted an autopsy of the Colt .45 revolver and found that there were worn joints and that the trigger control was not functioning properly, according to the source.
It became evident to prosecutors the gun could fire without pressure on the trigger, according to the source. https://abcnews.go.com/US/gun-fatal-set-rust-shooting-mechanically-improper-source/story?id=98760315
And since the fbi broke the trigger. Prove that it is false...
I suspect that if the movie is ever released....it will be a huge money-maker.
The publicity from this will guarantee it.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Edministrator
Sounds like it was a POS gun.
