cantdrv55's Avatar
All really good ideas, fellas. Thanks a bunch. I’ll take better pics tomorrow. I knew I can depend on the Pelican brain trust.
Old 02-22-2023, 10:39 PM
Information Junky
island911's Avatar
There ya go (jyl's post sleeve idea)
And some paint. IDK...
Old 02-22-2023, 10:56 PM
You do not have permissi
john70t's Avatar
The gate might be toast to my eyes.
As a minimum unscrew it,
set flat in driveway,
wood bleach/cleaner it and let soak in,
power wash, let dry a week or two,
unscrew, bar clamp it back to square, You can 'handshake' these to any length
screw back together with new hardware (stuff rotten holes with toothpicks),
soak with good stain ~ cherry colored two coats would be a guess but always err on the light side
add corner brackets https://www.strongtie.com/solutions Simpson now makes nice thick black pieces
Old 02-22-2023, 10:58 PM
Information Junky
island911's Avatar
Yeah, but the Simpson stuff is going to rust.
Use only SS for anything outdoors structural.
Old 02-22-2023, 11:02 PM
Corner braces are good but it will still sag over short period of time. If look isn't a huge concern, I have fixed my in law's big old swinging garage doors that been working fine for over 15 years with a couple pieces of plywood. This thing was built in the mid 20s. Square up your gate by squeezing the gate square with pipe clamps or by twisting a rope with t stick and a couple of screw eyes if you are cheap. Apply a 1 1/2' wide piece of 1/2' thick exterior plywood, glued and screwed (exterior wood glue. I use Franklin Titebond III with great result or urethane if you like to turn your fingers blacks for days) to both outer corners. Run plywood from top to bottom. Do it on the side that's less likely to be seen or the ugly side. You will get 10 years out of that in mild climates like Norcal easily. Notch around the hardware if necessary.
Old 02-23-2023, 12:51 AM
All great stuff but I thik Can'tdrive just want the gate to work without much fuss.
Old 02-23-2023, 12:52 AM
Super Moderator
cstreit's Avatar
I'd like to see what it looks like as well.
If I really had to get that post out, I'd probably sink some lag bolts into it, and use a bottle jack on either side to try and jack it out.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-23-2023, 06:17 AM
p911dad's Avatar
I did something similar last year. The post was a 6 X 6 end post and not rotted. I attached an "L" shaped iron bracket to the post (a wood block might also work) with 3 long screws and used my garage floor jack sitting on a board to slowly lift it out straight up and out. I didn't think it would work but I didn't want to have to dig it out. If that post is typical it is it there at least 24". I had to reposition the jack several times as the angle of the arm changed with the changing height of the "L" shaped arm as it came out.
Old 02-23-2023, 06:30 AM
Cajundaddy's Avatar
Agree with the others. Glue and screw the post to keep it solid, no need to dig it out. Lay out the gate and get it square. A diagonal cable with turnbuckle from the top hinge bolt can keep it that way and eliminate sag.
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 02-23-2023, 07:41 AM
wdfifteen's Avatar
Sounds like a great excuse to use explosives, but probably more socially acceptable to repair the top portion and let the bottom go.
Old 02-23-2023, 11:19 AM
Winner! Tell WDF what he won!
Old 02-23-2023, 11:30 AM
I'd change those hinges if it were mine. Get some of the kind they use for chain link fences. Thru bolt them to the post and gates. Much easier to adjust the swing of the gates with them.
Scott
'78 SC mit Sportomatic - Sold
Old 02-23-2023, 11:42 AM
craigster59's Avatar
Turnbuckle is great idea. Some real gate hardware wouldn't hurt either...
https://www.vandykes.com/gate-hardware/c/505/
https://www.hingeandlatch.com/fieldgate.php
Old 02-23-2023, 11:51 AM
cantdrv55's Avatar
Here are pics of the gate and posts. Based on some of the advice here, I’ll reinforce the posts with glue and screws plus square up the gate. I’ll probably replace the 1x6s with 14 guage galvanized fence wire. That’ll lighten the gate, prevent further sagging and be able to withstand wind gusts we often get here.
Old 02-23-2023, 11:54 AM
cantdrv55's Avatar
Old 02-23-2023, 11:55 AM
Model Citizen
herr_oberst's Avatar
Like others have said, your posts look fine. Your gates are the problem.
Designed to sag and rack from day one.
Old 02-23-2023, 12:00 PM
Kantry Member
oldE's Avatar
If your posts are plumb, your gates are warped. As above, through bolt the posts to eliminate or contain further splitting. Add diagonal bracing to the gate halves. I would add wheels to the ends of the gates to carry the weight.
I would not use turnbuckles and cables to support the sagging of the gates as that might worsen the warping.
Maybe just rebuild the gates so they are not twisted.
Best
Les
Best
Les
Old 02-23-2023, 12:08 PM
Model Citizen
I think look171 and his plywood fix are going to be the best way to go here. I think that's what I'd do. It'll eliminate the sag and the warp.
Old 02-23-2023, 12:18 PM
Counterclockwise?
What does your level say?
Rod
1986 Carrera
2001 996TT
Old 02-23-2023, 12:51 PM
GDNF2ET's Avatar
Those gates need wheels for support..
83 Monte Carlo, Turbo Buick drive train
93 Talon, awd/AT turbo, 10.97@127
91 Talon, awd/AT turbo
Old 02-23-2023, 01:28 PM
