cantdrv55's Avatar
Car door won’t unlock manually or with key fob. Door won’t open.
Is there a way to get my drivers side passenger door to open without tearing apart the door card from the inside? I can’t unlock it and I can’t open the door from the inside or outside. I can’t get at the door clips around the door which means the door card won’t come off unless I go ballistic on it. I’m wondering if a locksmith with a slim Jim can get at the lock. I’ve seen it in the movies but not IRL. Is there another way? Thx.
Old 03-27-2023, 05:23 PM
Battery good in the fob and the car?
Old 03-27-2023, 05:24 PM
Super Moderator
cstreit's Avatar
Does the inside handle feel loose - or stuck?
I wonder if the mechanism has come loose inside.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-27-2023, 05:25 PM
Still Doin Time
asphaltgambler's Avatar
What make/ model?
cantdrv55's Avatar
Battery is good. The other doors work just fine.
The lock sounds like it’s trying to unlock but doesn’t.
2003 Toyota Sequoia.
Old 03-27-2023, 05:34 PM
Send a message via AIM to fintstone
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 03-27-2023, 06:19 PM
cantdrv55's Avatar
Thanks Fint!
Old 03-27-2023, 06:41 PM
Fleabit peanut monkey
Bob Kontak's Avatar
The left rear door.
I have worked on an 2008-ish Ford Escape without success, including tearing off the inner door panel. (Rear driver's side)
What I finally found, without executing, is you need to identify where you can destroy the door latch to flip whatever lever is necessary to set the latch to open.
My plan is to get a used latch and tear it down to see what needs to be moved to release the "jaw" then replace the door latch.
You might want to buy a snake camera from Harbor Freight. You might want to get an angle grinder to open a hole in the inner door to march on in and destroy the latch with whatever tools willl work.
I don't think this is routine or easy and frankly, it sucks that these latches can fail in this mode.
I hope I'm wrong.
1981 911SC Targa
cantdrv55's Avatar
I’m taking apart the right rear door so I can see the innards.
Old 03-27-2023, 06:44 PM
Bob Kontak's Avatar
Good thinking. Keep me posted beause I can use the info.
1981 911SC Targa
Old 03-27-2023, 07:00 PM
pwd72s's Avatar
Weird thought...maybe a squirt of WD40 could loosen a stuck lock?
Old 03-27-2023, 11:48 PM
cantdrv55's Avatar
There’s no place to squirt oil tho. No key hole on the rear doors.
Old 03-28-2023, 01:16 AM
You do not have permissi
john70t's Avatar
There are pull rods running to the latch on the side of the door. Held by plastic clips usually.
If those fall off, the handle just flaps and does nothing.
But having both of those (inside/outside) fail at the same time would be unusual.
Old 03-28-2023, 05:30 AM
cantdrv55's Avatar
Agreed. I think the actuator itself is broken.
Old 03-28-2023, 07:06 AM
john70t's Avatar
The passenger seat might be able to be removed to get to the inner door panel. But IDK.
A slim jim with seal wedge might provide access to the manual level.
Sounds like a gymnastic project..
Wish you the best of luck. Take it easy with those plastic clips.
Old 03-28-2023, 07:19 AM
Senior Member
Superman's Avatar
A locksmith could likely have that door open in ten seconds.
Mocha 1978 911SC. "Coco"
Old 03-28-2023, 07:30 AM
Bob Kontak's Avatar
Called the local locksmith and they said they work on the locks and not the latches.
1981 911SC Targa
Old 03-28-2023, 08:04 AM
john70t's Avatar
Might be able to take off the inner door pull and snake a USB camera down to the latch
Old 03-28-2023, 09:42 AM
MBAtarga's Avatar
I just replaced the driver's door lock actuator on my 08 Silverado PU last week. The GM lock actuators are a known failure point. Look on youtube - there is likely a video showing replacement for your vehicle. I bought the part of Amazon for less then $20. Of course - you'll have to get the door card off first.
Mark
'83 SC Targa - since 5/5/2001
Old 03-28-2023, 10:13 AM
908/930's Avatar
I am not familiar with that lock but check if there is a return spring in the latch that is broken. I had a car years ago that this happened too, it would not unlock until the internals under the handle were back in to correct position.
Old 03-28-2023, 11:45 AM
