weekend wOrrier
Model Citizen
My old beater is over 25 years old. 3/4 particle board, 1/4" hard (tempered) masonite treated with Watco oil and edged with oak banding.
I whale on this thing, and it looks like it but it's been a stalwart, plus, it knocks down into 4 'panels' so I can move it as I move. I'm jealous of you guys with the nice Wilton vices. This thing is kind of a turd.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
A Wilton is a piece of machinery. I don't mistreat machinery and therefore do not own a Wilton other than the little Shop King I use every day. But my welding vise is HF and my cemented-in-a-bucket moveable vise is a Columbian and it wasn't the prom queen when I got it. Those last 2 live outside and I pour oil on them regularly and cover with a plastic bag.
The HF vise flips over, swivels, holds pipe and a couple extra features. Not bad for 10 bucks used. |
I've got a big pig vise that flips for a pipe too. Bigger the better for vices. Mine is 90 lbs. and made in China. The only decent tool from China I own. Is a Shop King like a Shop Smith?
Model Citizen
That is very true about the Wilton. I just wish this thing had a decently even clamp pressure across the face of the jaws. I believe the nut and the screw are somehow misaligned and it 'pulls' to one side.
I've been looking at those HF "Doyle" branded vises. They're getting damn good reviews for the 150 or whatever bucks they cost. (If I'm honest, I'd be a poor workman with the best tools, so blaming my tools at this level is just kidding myself at the most amateurish level)
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" Last edited by herr_oberst; 04-07-2023 at 03:50 PM.. |
Whoa! That wouldn't go anywhere. My single layer seems solid as a rock.
Marv Evans '69 911E |
My man cave workbench is 16' long . I bought three metal framed workbenches at an industrial close out . They had 3/4" thick wood tops . I bolted the frames together end to end . Then took another layer of 3/4" and glued and screwed to the existing tops overlapping the seams .
Then had a local metal shop bend me up a metal top . It's galvanized steel and has a backsplash and front apron . I used silicone adhesive and some screws to install the top . It is super easy to clean , it looks good and it is stout !!! |
Here's my workbench. It's 6 months old.
I have 3 that I use a lot.
One is a old kitchen cabinet with varnished particle board. One is a framework of 2" x 4".s on casters with a brown Formica covered counter top. The last is an old display with drawers and a set of sliding doors with viper green Formica covered counter top. I like the Formica because it's cheap, quiet and when it is time to clean up, I spill some old paint thinner on it and wipe it off and give it a good buff. |
My top is stainless steel on a hollow metal door with a unistruct frame. Steel casters. Strong like bull.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
I generally make mine 8 foot wide and 2 foot deep, with a shelf below. One piece of 4 x 8 x 3/4 ripped in half. 2 x 4 for legs and shelf support. I screw mine to the wall and make it high enough that when I’m standing at the workbench, it’s comfortable to work on something.
I went with MDF. Home Depot cut the 4x8's the long way for me. I know I'll never keep it clean. That is one downside. Built this about a year ago. It's a relatively cheap solution that provides a lot of work space.
-Mark B. Hardware Store Engineer 1988 911 - 3.6 1999 SL500 - Gone 1995 M3 - LS2 - Gone 1993 RS America - Gone |
Platinum Member
Lots of people downsizing. I've picked up butcher block benches on FB marketplace for under $100.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
I like that.
Sold: 1989 3.2 coupe, 112k miles |
300hp 1800lbs is the goal
![]() Hardwood flooring bonded to a piece of mdf counter top, with some angle iron welded up to make an edge. I think I used rocker guard on the angle iron. It's holding up quite well. I use a piece of sacrificial polyethylene plastic (1/4"?) if I plan on beating on the top. Everything (including the rockerguard) was free. It's amazing what people give away on FB Marketplace/kijiji I have a drill press on one corner, and a bench vise on the opposite. It's mounted on some ikea base cabinets with extra feet, and it's also attached to the wall.
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier.
Workbench
I have a WWII left over workbench that is about 3 feet by 10 feet in size. It is all hardwood (red oak?) and is heavy as it can be! The top was made by stacking 2x6 pieces together, bored holes thru front to rear and used threaded rod with a heavy spring (like a valve spring) to keep all the pieces together. This way, if the wood swells it can expand and then go back to normal when dry. No buckling! This thing is built so sturdily I think it may have been intended for the maintenance deck on an aircraft carrier! My grandfather bought it right after WWII, used it in his service station garage, gave it to my father when he sold the station. My dad used it in an appliance repair shop for many years and then he gave it to me to use in my shop. Now it has been in my family for a bit over 70 years and is still going strong! The only downside is that it take 6-8 people to move it!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
