I wash is cold water all the time. Clothes just as clean. Save $$$
Old 05-17-2023, 11:54 AM
The temps in that article are lower than just about every other page on the 'Net.
https://www.google.com/search?&q=washing+machine+water+temperatures
Here's one that says that the usual "hot" range (3 dots) is >120ºF.
Old 05-17-2023, 11:56 AM
Counterclockwise?
I feel like you're going to need to ask something more specific.
Because based on your question, the machines mixes water and soap and runs through various cycles.
Hot water is generally 130 degrees Fahrenheit (54 degrees Celsius) or above.
Warm water is generally between 90 and 110 degrees Fahrenheit (32 to 43 degrees Celsius).
Cold water is generally between 60 and 80 degrees Fahrenheit (16 to 27 degrees Celsius).
Most water heaters are set to 120-140º. So the washer will provide 100% hot water from the start if set to hot.
But if you turn the hot water on, and the water that comes out for the first 5-10 secs (or longer) because the water in the pipes is cold, then that's the water that you're going to get.
It's possible that some washing machines may heat the water, but I suspect those are rare, and probably only high end.
My question is how does a washing machine work.
Not how do you operate a washing machine.
Rod
1986 Carrera
2001 996TT
Old 05-17-2023, 11:57 AM
This ... but I still use hot for the load of undies and socks .... 'cause mom said to decades ago !
Old 05-17-2023, 11:58 AM
What?
Eric Hahl's Avatar
Generally, you have to feed them, put a roof over their head, sometimes even marry them.
________________________________________
Eric Hahl
85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD)
2015 981 Cayman S (Sold)
23 Outback Wilderness & 23 BMW R1250GS
Old 05-17-2023, 12:28 PM
Y'all need to read that link I posted
What? Read the previous posts, and a link that explains it? Who do you think we are?
You can't make me read!
Old 05-17-2023, 12:32 PM
It's not how I usually roll either ....
I read the title, never watch any videos, jump to the bottom and post away .
For folks like us ...
Regardless of temp selection, the washing machine starts out cold .... unless there is a LOT of wine involved
Old 05-17-2023, 01:05 PM
Counterclockwise?
I'm okay with cold as long as I get a sandwich first.
Rod
1986 Carrera
2001 996TT
Old 05-17-2023, 01:09 PM
