Daily Driver Help Needed (Jetta)
My daily driver - 96 Jetta with 2.0L engine is not starting-no fuel, no spark from my testing, but it does crank. Any help appreciated, even if pointed to good bb. VWVortex isn't doing it.
John
86 Coupe - Sold
Macan GTS
Ducati Multistrada
Old 06-08-2003, 03:08 PM
one of gods prototypes
bell's Avatar
disconnect the battery for about 5 minutes......this will reset the computer.......worth a shot.
also does that car have a "rollover" cutout for the fuel? if it does it may need reset, check your owners manual for where the reset button is.
Brought to you by Carl's Jr.
Old 06-08-2003, 03:35 PM
Bell,
I've disconnected the battery to reset ECU already, no luck. Rollover detection is not an option on the vehicle.
It does seem like the imobilizer function though with no fuel and no spark. Searching for bad wiring at the moment.
John
86 Coupe - Sold
Macan GTS
Ducati Multistrada
Old 06-08-2003, 06:08 PM
nostatic's Avatar
ummm...use the '86 as your daily driver. Problem solved.
Old 06-08-2003, 06:57 PM
Too many miles driven daily, plus the midwest weather kind of keeps me from using the '86 as the daily driver. Thanks for the help though.
John
86 Coupe - Sold
Macan GTS
Ducati Multistrada
Old 06-08-2003, 07:43 PM
Information Junky
island911's Avatar
"no fuel, no spark . . ."
Sounds like an ingnition side problem. (I'm fairly certain that the fuel pump will not run unless the hall sensor (distributor) gives x-number of pusles per second.)
Old 06-08-2003, 08:09 PM
The Hall Sensor is the next item to check. You're right, it is part of the distributor assembly on this vehicle.
John
86 Coupe - Sold
Macan GTS
Ducati Multistrada
Old 06-09-2003, 08:49 AM
Information Junky
island911's Avatar
I have had the wiring to the hall sensor fail on one of these. I vaguely remember it being a broken wire (at the solder joint) under the hall sensor.
Anyway, the quick check is to see if voltage is getting to the sensor. . ..something like ~3V.
Old 06-09-2003, 09:28 AM
Island,
I'm at work and don't remember if this is a three wire device or not. If so, isn't it the middle terminal that provides the output?
I will do some testing tonight when I get home.
John
86 Coupe - Sold
Macan GTS
Ducati Multistrada
Old 06-09-2003, 01:06 PM
Information Junky
island911's Avatar
Well I'll preface things by saying I'm going off a decade old brain-cells on this.
Anyway, I'll sugest you test the input. . . being that the voltage output, from the hall effect is minimal (measuring induced electron drift)
The Bentley shop manual should tell you which pins should be tested for voltage.
Or, just simply remove the dist' plate that carries the hall sensor, and look at the bottom side for broken wires.
Old 06-09-2003, 01:43 PM
Finally got some time to debug, and to make nostatic happy I've been driving the 86 daily.
Brought home the diagnostic tool from work, fault code P1340 which is cam / crank sensor sequence problem of some sort. Cam sensor (Hall Sensor) signal looks good on scope. With the sensor disconnected, results in the same fault code. Must be wiring problem between sensor and ECU. More searching tomorrow, another excuse to drive the 86.
John
86 Coupe - Sold
Macan GTS
Ducati Multistrada
Old 06-10-2003, 07:37 PM
What?
trj911's Avatar
Hey John,
Do you still need a track pass for USGP Fan Appreciation Day this Sunday? I have an extra one if you do. Just meet us at the Big Lots parking lot on 30th street between 9:15 and 9:30 AM on Sunday. We'll head over to the track as a group at 10:15.
Tom
Tom J.
911SC Cab
SCWDP
CaymanS
Old 06-12-2003, 06:43 AM
Tom,
Yes I do, I had troubles sending e-mails to you, thought your account must have changed. What else do I need to bring?
John
86 Coupe - Sold
Macan GTS
Ducati Multistrada
Old 06-12-2003, 12:24 PM
What?
trj911's Avatar
Try my work email Tom_jacobson@natcity.com
Just bring your car and yourself. I will be coming with my brother and my 2 boys.
Here is the email I got from the track. See you Sunday!
This email is to confirm that your RSVP has been received for the June 15th USGP Customer Appreciation event. Remember, you are only required to have one ticket per vehicle. Also, please be sure to sign the waiver on the back of the ticket prior to entering the facility.
In addition, we would like to make you aware that we are launching our inaugural Indianapolis Motor Speedway email newsletter early next month. The newsletter will feature insightful stories about our three distinct events at the Indianapolis Motor Speedway, as well as highlight special offers and promotions throughout the year. To make sure you receive the monthly newsletter click on the link, http://ims.brickyard.com/ims/club/cust_survey.php, and fill out the proper information.
Once again, we look forward to seeing you on Sunday June 15th.
Tom J.
911SC Cab
SCWDP
CaymanS
Old 06-13-2003, 06:13 AM
