Model Citizen
herr_oberst's Avatar
Best comment: "But they still charged an hour's labor"
Old 07-13-2023, 09:15 AM
pwd72s's Avatar
LOL! Meanwhile, in your garage...
Old 07-13-2023, 09:27 AM
fastfredracing's Avatar
I wonder if the caliper mounting arrangment ( how the bolts hold the caliper to the knuckle ) came from the need for quicker brake changes during racing . That is awesome. 2 bolts a brake line , a quick bleed, and you're off .
No left turn un stoned
Old 07-13-2023, 11:30 AM
That was cool!
Glad I'm not the only one who reads the comments...lol.....that's the best part of a given video sometimes!
How do you guys like those coveralls? I think if I ever got my hands on a pair, I would just hang them up like art work!
Old 07-13-2023, 01:22 PM
If you were the driver,
how nervous would you be diving into the first
high-speed corner after that brake change?
I believe I'd be pumping quite a bit on the straight,
just to make sure
Old 07-13-2023, 11:45 PM
A930Rocket's Avatar
When looking at Aeroquip or similar fittings, I’ve seen quick disconnect brake lines, and wondered about them. I was thought that a small amount of air would be introduced when disconnecting and reconnecting. I suppose a couple of quick pumps of the brakes to bleed them and it would be good.
That said, that was not their first rodeo and they feel comfortable in doing it and the driver using them.
Old 07-14-2023, 05:36 AM
"Look Buddy, it's an hour minimum for labor. The parts bill is $6,000."
Old 07-14-2023, 05:52 AM
Still Doin Time
asphaltgambler's Avatar
Back when there was Trans-am racing here and domestic manufactures got involved, one particular standout ( cheating? ) was the AMC team who used P 917 disc brake setup all 'way round on their Javelins. They had AMC purchase them under contract from Porsche, then put a AMC part # on all the required "kit" parts so to make it legal. Then they added a second brake booster which sole purpose was to suck the fluid back in a reservoir which drew the caliper pistons (and pads) back to full retract for easy replacement on a pit stop. Genius!
Old 07-14-2023, 07:46 AM
Rodger Penske and Mark Donohue
Old 07-14-2023, 01:05 PM
IIRC they had two master cylinders (one for the front, one for the rear) and a booster on the front circuit only.
'80 SC Targa
Avondale, Chicago, IL
Old 07-14-2023, 01:29 PM
Navin Johnson
TimT's Avatar
They didn't bleed the brakes in that pit stop.. the caliper and hose is bled beforehand
They have something like Staubli dry break fittings..
'69 911 GT-5
'75 914 GT-3
and others
Old 07-14-2023, 02:09 PM
Motorsport Ninja Monkey
Captain Ahab Jr's Avatar
Sloppy pit stop
Not the guys changing the brakes, they did their job quicker than the refueller that cost the team time
Refueller took 5 attempts to break the fuel hose dry break disconnect
4x 0.3sec reaction time = 1.2sec too long for the pit stop
Wer rastet, der rostet
He who rests, rusts
Old 07-14-2023, 03:20 PM
Senior Member
Superman's Avatar
Amateurs. They didn't even check the oil.
Mocha 1978 911SC. "Coco"
Old 07-14-2023, 03:29 PM
