Op mentioned downstream outlet has no power not up.
I was replying to Steve's scenario. And the OP's scenario: if downstream outlets are dead and the GFCI outlet is live, that is not a GFCI issue, unless the GFCI has failed internally.
Old 07-24-2023, 08:13 AM
Rtrorkt's Avatar
THey are awesome. Klein $19
https://www.homedepot.com/p/Klein-Tools-Non-Contact-Voltage-Tester-Pen-50-1000V-AC-NCVT1PR/317460355
or
https://www.amazon.com/Non-Contact-Detector-Klein-Tools-NCVT1P/dp/B099SJ6469/
These are also a must have, IMO. You can confirm outlet wiring and they'll test a GFCI. And I think they are supposed to be a better test than the button on the GFCI, but I don't remember exactly what I read.
Thanks to all who have weighed in. I have called in an expert so we will see what he says. Using my tester on the GFCI outlet it tests green or all ok. Mystery. When expert sparky figures it out I will post the solution
'86 944T black/red, chip, fuchs 8's and 9's- Sold
'97 Boxster silver/red, big mistake - Sold
'99 C2, silver/black, RoW M030 - sold
"69 912 white w/ '86 3.2L (like the pic, just not the pic)
Old 07-24-2023, 12:47 PM
I think you did the right thing. The root cause of what you're experiencing is probably going to need more expertise than you have.
There's a time to try on your own, and a time to get help.
Old 07-24-2023, 12:51 PM
