Fleabit peanut monkey
Bob Kontak's Avatar
Flourescent bulb advice - Circular ceiling light
My place is a 1930 (built) farm house with a pretty big kitchen added onto the back. (I left my reading glases at the shop so forgive typing errors)
There is a circular flourescent cieling light and the room is not very bright. Below ae pictures of the light and close ups of the bulb description. I know nothing about bulbs.
Please help me choose brighter bulbs while having a color that is acceptable for inside a home.
If the existing kit should be pitched and replaced please advise. I rent but get on wth lndlords well.
Thanks for the assistance,
Here's my 1954 Frigidare by General Motors. It is so cool and it works fine.
1981 911SC Targa
Old 11-17-2023, 04:34 PM
Zeke's Avatar
I removed the old tubes and ballasts and bought direct to line voltage LED replacements. You can get both sizes but one of the larger LEDs is all you need and that will double the light. You can always add the 2nd smaller one.
Old 11-17-2023, 04:40 PM
If it were me, I would pitch it and see if you can get some sort of LED solution.
Is there some sort of glass cover that goes over those two FL bulbs?
Now days you can get LED bulbs in different colors and brightness levels.
If you need a whole new luminaire that could be an issue because different paint may show.
Sold: 1989 3.2 coupe, 112k miles
Old 11-17-2023, 04:41 PM
Kantry Member
oldE's Avatar
We had those in a couple of rooms in the house I grew up in. I suggest you just replace them with LED fixtures, especially if you want brighter light.
Best
Les
Best
Les
Old 11-17-2023, 04:43 PM
You do not have permissi
john70t's Avatar
I did the same with a dozen shop lights.
(note: none of the "Direct replacement" LED worked with my existing ballasts, even the known-good ones. I tried every brand and combo.)
Those bulbs are called Ballast-Bypass or Direct-Wire.
(make sure you write this in big letters inside the fixture for the next guy.)
Good thing is they are wired in parallel so only one will burn out at a time.
What a difference. Instant on in winter. Good Light. No ballast buzzing.
Bob- Your key words are Lumens and Spectrum
Lumens is total light output. That inner bulb looks weak but you are probably not going to get much more out of that fixture.
Spectrum is color. https://blog.lightingsupply.com/blog/what-are-warm-white-soft-white-cool-white-and-daylight-light-bulbs
Lower is yellow and cozy but reading might be more difficult.
Higher is blue and harsh.
I personally prefer Soft White 3000K to 3500K and have above the kitchen sink set to Warm White.
A large flat 2' x 4' surface mount box would provide a lot of diffused light but would look "modern".
Or consider a stand-up LED lamp. Some angle up and cast light off the ceiling.
Old 11-17-2023, 05:26 PM
john70t's Avatar
Check with the LL before any major changes of course.
Many won't care especially if you are paying for it...but they want it installed correctly.
Old 11-17-2023, 05:29 PM
Super Moderator
cstreit's Avatar
Honestly the LED panel lights are so cheap, I'd be tempted to just replace it. THose old circle bulbs suck.
...but you want something in the 4-5k color range I think. Not hospital white, slightly warmer.
https://www.amazon.com/Afaoel-Temperature-Circular-utilities-Installation/dp/B0C3D4TH2J/ref=sr_1_7?crid=GUAEA7MZHDFY&keywords=circular+led+light+5000k&qid=1700272419&sprefix=circular+led+light+5000k%2Caps%2C88&sr=8-7
Probably less than 2 bulbs cost-wise
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 11-17-2023, 05:51 PM
john70t's Avatar
Some of the panels are switchable between color spectrum.
(button on the side plus a remote.)
Old 11-17-2023, 05:58 PM
Driver
Noah930's Avatar
I would get a new light fixture and use LED bulb(s) in them. You can get a functional and not-ugly flushmount for $50 at a Home Depot or an online lighting/home furnishings store, or you could spend several hundred dollars for something prettier. Off the top of my head, some of the online vendors we shopped when we remodeled our house a few years back: Wayfair, Lumens, Rejuvenation Hardware.
If the diameter of the new fixture is smaller than the old one (and you don't want to leave a paint ring or have to repaint the ceiling), there are medallions that you can buy and stick to the ceiling for cosmetics. I'd get the approval of the landlord first. Don't be totally surprised if the landlord wants a real electrician to install it (or not) for safety reasons.
1990 Black 964 C2 Targa
Old 11-17-2023, 07:02 PM
Bob Kontak's Avatar
Direct replacement at Lowes. Chose 4000 for the color on each. That was the middle choice. Easy peasy.
Thank you all.
1981 911SC Targa
Old 11-18-2023, 04:08 PM
That was my first thought, "there's got to be an LED replacement that would be brighter with better color."
If Zeke says it's so, then it certainly is.
Old 11-18-2023, 04:27 PM
Thank you all.
Awesome!
Old 11-18-2023, 04:29 PM
Bob Kontak's Avatar
+1 on that.
I bet you could get more lumens out of those types but I'm just talking without researching.
I just walked into Lowes and there they were. $32 and the directions said nothing about wiring. Also the lumens were about three tines as much. Sold to the lazy guy!
1981 911SC Targa
Old 11-19-2023, 05:36 AM
+1 on that.
Awesome old stove! I wish we had one like it.
Are all of the cabinet pulls diagonal like the ones over the stove hood? That's interesting. I don't remember ever seeing any like that before.
Old 11-19-2023, 07:06 AM
Zeke's Avatar
+1 on that.
I guess you can get the direct replacement now that does not replace the ballast. Best deal for you as all you did was "change the light bulb."
Old 11-19-2023, 12:00 PM
Dr J's Avatar
I recently replaced a lamp that was very unsatisfactory with this:
https://www.amazon.com/dp/B0BNMV9H1Z?ref=ppx_yo2ov_dt_b_product_details&th=1
Very happy with it. Super bright and super easy to install.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 11-19-2023, 12:04 PM
Bob Kontak's Avatar
Forgive the mess but yes.
My brother was saying that was kind of strange.
1981 911SC Targa
Old 11-19-2023, 04:00 PM
Nice - glad it worked out. I have replaced some of my outdoor "porch lights" with LED fixtures after replacing "X" many bulbs over the years....and rusty fixtures. So far so good and much brighter!
Old 11-19-2023, 04:19 PM
I like it. It's certainly not anything that I remember ever seeing.
Old 11-19-2023, 06:08 PM
Bob Kontak's Avatar
They angle the other way for the cupboards right of the sink. It limits what you can see at one time but I'm not cooking for a gang of people.
1981 911SC Targa
Old 11-20-2023, 06:06 AM
