Fleabit peanut monkey
Flourescent bulb advice - Circular ceiling light
My place is a 1930 (built) farm house with a pretty big kitchen added onto the back. (I left my reading glases at the shop so forgive typing errors)
There is a circular flourescent cieling light and the room is not very bright. Below ae pictures of the light and close ups of the bulb description. I know nothing about bulbs. Please help me choose brighter bulbs while having a color that is acceptable for inside a home. If the existing kit should be pitched and replaced please advise. I rent but get on wth lndlords well. ![]() ![]() ![]() Thanks for the assistance, Here's my 1954 Frigidare by General Motors. It is so cool and it works fine. ![]()
1981 911SC Targa |
I removed the old tubes and ballasts and bought direct to line voltage LED replacements. You can get both sizes but one of the larger LEDs is all you need and that will double the light. You can always add the 2nd smaller one.
If it were me, I would pitch it and see if you can get some sort of LED solution.
Is there some sort of glass cover that goes over those two FL bulbs? Now days you can get LED bulbs in different colors and brightness levels. If you need a whole new luminaire that could be an issue because different paint may show.
Sold: 1989 3.2 coupe, 112k miles |
Kantry Member
We had those in a couple of rooms in the house I grew up in. I suggest you just replace them with LED fixtures, especially if you want brighter light.
Best Les
Best Les My train of thought has been replaced by a bumper car. |
You do not have permissi
(note: none of the "Direct replacement" LED worked with my existing ballasts, even the known-good ones. I tried every brand and combo.) Those bulbs are called Ballast-Bypass or Direct-Wire. (make sure you write this in big letters inside the fixture for the next guy.) Good thing is they are wired in parallel so only one will burn out at a time. What a difference. Instant on in winter. Good Light. No ballast buzzing. Bob- Your key words are Lumens and Spectrum Lumens is total light output. That inner bulb looks weak but you are probably not going to get much more out of that fixture. Spectrum is color. https://blog.lightingsupply.com/blog/what-are-warm-white-soft-white-cool-white-and-daylight-light-bulbs Lower is yellow and cozy but reading might be more difficult. Higher is blue and harsh. I personally prefer Soft White 3000K to 3500K and have above the kitchen sink set to Warm White. A large flat 2' x 4' surface mount box would provide a lot of diffused light but would look "modern". Or consider a stand-up LED lamp. Some angle up and cast light off the ceiling.
Meanwhile other things are still happening. |
Check with the LL before any major changes of course.
Many won't care especially if you are paying for it...but they want it installed correctly.
Super Moderator
Honestly the LED panel lights are so cheap, I'd be tempted to just replace it. THose old circle bulbs suck.
...but you want something in the 4-5k color range I think. Not hospital white, slightly warmer. https://www.amazon.com/Afaoel-Temperature-Circular-utilities-Installation/dp/B0C3D4TH2J/ref=sr_1_7?crid=GUAEA7MZHDFY&keywords=circular+led+light+5000k&qid=1700272419&sprefix=circular+led+light+5000k%2Caps%2C88&sr=8-7 Probably less than 2 bulbs cost-wise
Chris ---------------------------------------------- 1996 993 RS Replica 2023 KTM 890 Adventure R 1971 Norton 750 Commando Alcon Brake Kits Last edited by cstreit; 11-17-2023 at 04:55 PM.. |
Some of the panels are switchable between color spectrum.
(button on the side plus a remote.)
Driver
I would get a new light fixture and use LED bulb(s) in them. You can get a functional and not-ugly flushmount for $50 at a Home Depot or an online lighting/home furnishings store, or you could spend several hundred dollars for something prettier. Off the top of my head, some of the online vendors we shopped when we remodeled our house a few years back: Wayfair, Lumens, Rejuvenation Hardware.
If the diameter of the new fixture is smaller than the old one (and you don't want to leave a paint ring or have to repaint the ceiling), there are medallions that you can buy and stick to the ceiling for cosmetics. I'd get the approval of the landlord first. Don't be totally surprised if the landlord wants a real electrician to install it (or not) for safety reasons.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa Last edited by Noah930; 11-17-2023 at 06:09 PM.. |
Direct replacement at Lowes. Chose 4000 for the color on each. That was the middle choice. Easy peasy.
Thank you all. ![]()
1981 911SC Targa |
If Zeke says it's so, then it certainly is.
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
Awesome!
I bet you could get more lumens out of those types but I'm just talking without researching. I just walked into Lowes and there they were. $32 and the directions said nothing about wiring. Also the lumens were about three tines as much. Sold to the lazy guy!
1981 911SC Targa |
Are all of the cabinet pulls diagonal like the ones over the stove hood? That's interesting. I don't remember ever seeing any like that before.
I recently replaced a lamp that was very unsatisfactory with this:
https://www.amazon.com/dp/B0BNMV9H1Z?ref=ppx_yo2ov_dt_b_product_details&th=1 Very happy with it. Super bright and super easy to install.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! |
My brother was saying that was kind of strange. ![]()
1981 911SC Targa |
Nice - glad it worked out. I have replaced some of my outdoor "porch lights" with LED fixtures after replacing "X" many bulbs over the years....and rusty fixtures. So far so good and much brighter!
Old dog....new tricks..... |
I like it. It's certainly not anything that I remember ever seeing.
They angle the other way for the cupboards right of the sink. It limits what you can see at one time but I'm not cooking for a gang of people.
1981 911SC Targa |
Thread Tools | |
Rate This Thread | |
