Arizona_928's Avatar
Built by a company that can’t even get 30k miles out of an engine….
dolor et pavor
Copyright
Old 12-04-2023, 05:26 PM
Bland
unclebilly's Avatar
A cad model and animation aren’t the same as a tested prototype. If an electric car is 600 hp, this means 4 150 hp motors. No way those 3/4” diameter gears with 1/4” shafts are going to hold up to 150 hp. I guess the braking is regenerative… so braking hp is maybe 300 hp? No way this survives a spirited drive around the block.
Old 12-05-2023, 05:43 AM
Originally Posted by Zeke View Post
I missed how the shaft steers too. And camber change, how is that accommodated?
AFA placing the motors IN the wheels, that increases unsprung weight. So for that matter, all those gears and housing must mean something.
Yes, they conveniently forgot about all the other angles it needs to work at.
E.g. bushing compression/steering/camber/etc.
Sold: 1989 3.2 coupe, 112k miles
Old 12-05-2023, 09:30 AM
You do not have permissi
john70t's Avatar
Maybe the gears will be cupped...sorta like a CV joint..
Old 12-05-2023, 09:38 AM
Bill Douglas's Avatar
I've heard some outfit called Porsche have good ones. The word on the street is they can last 200,000 miles. Maybe they could copy a set off a SC.
Old 12-05-2023, 10:36 AM
Counterclockwise?
Designed by some guy sitting at a computer. Maybe even a school project.
Rod
1986 Carrera
2001 996TT
Old 12-05-2023, 11:13 AM
Bland
unclebilly's Avatar
My thoughts exactly. No idea that 120mm is just under 5” which makes those gears under 1” in diameter and totally incapable of transmitting the necessary loads.
Old 12-05-2023, 11:40 AM
john70t's Avatar
AI could do that.
"Transmit power from A to B using X parameters"
Could even be pneumatic. Need storage for unicorns.
Old 12-05-2023, 11:57 AM
weekend wOrrier
Fools! All of you!!!!
Basically the only new principle involved is that instead of power being generated by the relative motion of conductors and fluxes, it is produced by the modial interaction of magneto-reluctance and capacitive diractance
marginal gains enthusiast
Old 12-05-2023, 12:03 PM
Counterclockwise?
What I found funny is the single motor is 10 times bigger that the singles.
Rod
1986 Carrera
2001 996TT
Old 12-05-2023, 12:11 PM
Just engineers looking for things to over complicate. The Cv joint is still there in the video to allow for turning. Its just shorter to alow for more cargo space. Which makes no sence because there is usually less suspention travel than steering angle. But im no engineer.
Old 12-07-2023, 02:36 PM
weekend wOrrier
Well, you have correctly pointed out the increased cargo space could be a real bonus provided the said cargo is so light it does not challenge the the decreased suspension travel!
Old 12-07-2023, 03:43 PM
Zeke's Avatar
That makes sense.
Old 12-08-2023, 08:33 AM
