Built by a company that can’t even get 30k miles out of an engine….
dolor et pavor Copyright |
Bland
A cad model and animation aren’t the same as a tested prototype. If an electric car is 600 hp, this means 4 150 hp motors. No way those 3/4” diameter gears with 1/4” shafts are going to hold up to 150 hp. I guess the braking is regenerative… so braking hp is maybe 300 hp? No way this survives a spirited drive around the block.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
E.g. bushing compression/steering/camber/etc.
Sold: 1989 3.2 coupe, 112k miles |
You do not have permissi
Maybe the gears will be cupped...sorta like a CV joint..
Meanwhile other things are still happening. |
Counterclockwise?
Designed by some guy sitting at a computer. Maybe even a school project.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Bland
My thoughts exactly. No idea that 120mm is just under 5” which makes those gears under 1” in diameter and totally incapable of transmitting the necessary loads.
AI could do that.
"Transmit power from A to B using X parameters" Could even be pneumatic. Need storage for unicorns.
weekend wOrrier
Fools! All of you!!!!
Basically the only new principle involved is that instead of power being generated by the relative motion of conductors and fluxes, it is produced by the modial interaction of magneto-reluctance and capacitive diractance
100% narcissist |
Counterclockwise?
What I found funny is the single motor is 10 times bigger that the singles.
Just engineers looking for things to over complicate. The Cv joint is still there in the video to allow for turning. Its just shorter to alow for more cargo space. Which makes no sence because there is usually less suspention travel than steering angle. But im no engineer.
82 SC , 72 914 |
weekend wOrrier
100% narcissist |
That makes sense.
