Evil Genius
Rusty Heap's Avatar
Why did my Piston and Rings Blow Up?
I've got Blown Piston dome and Rings on my 2021 KRX Side x Side with 1500 miles. It started smoking on the trail. I did a compression test. Left was ~150 psi, Right was only 60. It was time for the dealer and warranty coverage. They tore the top end down to find right piston missing most of the rings and piston dome/skirt that retains the rings.
Detonation? Doesn't look like I'm running lean........always use Premium 92 octane so it's not pinging.
Brain Trust thoughts?
Life is a big ocean to swim in.
Wag more, bark less.
Old 12-07-2023, 12:05 PM
908/930's Avatar
Not sure but I think you floated your exhaust valves and they made contact. Any marks on them?
Old 12-07-2023, 01:09 PM
Super Moderator
cstreit's Avatar
...boy that sure LOOKS like detonation. Bad gas?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-07-2023, 02:45 PM
Classic high rpm detonation. I wish you had seen these before you stopped by yesterday, I could have shown you some Porsche pistons that look like that.
When you get it back, we should put my LM1 on it and get some A/F readings. What with modern emissions requirements, even on "off road" equipment, I bet it's running lean as hell. Is there any way to alter the fuel injection to provide more fuel?
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 12-07-2023, 02:49 PM
Almost Banned Once
sc_rufctr's Avatar
It could have been an incidental failure... As in "One in then thousand".
Sometimes thing break for no apparent reason.
- Peter
Old 12-07-2023, 03:33 PM
Control Group
Tobra's Avatar
yeah
Old 12-07-2023, 03:49 PM
It’s not a Polaris!
Haha just kidding that sucks. I agree detonation.
Old 12-07-2023, 04:25 PM
LWJ LWJ is online now
Yikes!
I agree that it is almost certainly tuned very lean.
Dirty filter, bad gas, something else, can make it go even more lean very quickly.
And, then this is the result.
Old 12-07-2023, 07:07 PM
Jeff Alton's Avatar
Detonation..........
www.turn3autosport.com
Old 12-07-2023, 08:47 PM
FUSHIGI
There seem to be forums for almost everything ever made. Any mention of this or similar in those?
Cults require delusions.
Old 12-08-2023, 02:28 AM
wdfifteen's Avatar
Ring land collapse like that is almost always premature ignition. As many here have said, a lean mixture can cause it. So can timing going too far advanced at working rpm. Given how black and moist the combustion chamber looks my money would be on timing.
Old 12-08-2023, 02:43 AM
It can also be insufficient ring gap, no? Rings expand, lock up, and the land fails?
Old 12-08-2023, 06:31 AM
That's what I was thinking.
Old 12-08-2023, 02:26 PM
wdfifteen's Avatar
I suppose so. There would probably be a lot of cylinder wall scoring and I would expect the ring land would have failed pulling up instead of collapsing down.
Old 12-09-2023, 07:11 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Injector flow may have been compromised if everything is stock as to factory settings.
1981 911SC Targa
Old 12-09-2023, 10:08 AM
gduke2010
gduke2010's Avatar
Extreme heat or an injector stuck open.
Old 12-09-2023, 10:12 AM
wdfifteen's Avatar
How is the top ring fitting in the other piston?
Old 12-09-2023, 12:06 PM
Make Bruins Great Again
Por_sha911's Avatar
...boy that sure looks like detonation. Bad gas?
+1
Joe
Old 12-09-2023, 06:44 PM
Bob Kontak's Avatar
A neighborood car acquaintance showed me the pistons out of his 930 that suffered detenotation. They were melted on that edge and down the side a half inch.
Different variables.
1981 911SC Targa
Old 12-10-2023, 05:44 AM
Bad injector
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 12-10-2023, 04:39 PM
