Drive Shaft Problem
Went to visit my kid in Houston yesterday (almost wiped out a GT3 passing me on the right going well faster than traffic). His Land Rover was having a vibration at low speed.
I drove it about 50 to 75 feet and it was very obvious. Pretty sure it is the front drive shaft, which I had replaced about 2 years ago. Seems the sunroof drain is right above one joint and it has ruined the new shaft. The drain should have a nipple but this one is missing, which I'm thinking would have diverted the water elsewhere.
I grabbed it and that joint is very loose, able to move laterally by hand.
I seem to recall the new one being movable but stiff, taking force to change planes. Is my memory correct? Sort of like how a ball joint is stiff but can be moved.
Thoughts? He said it smoots out at speeds above 40 mph. God help me that he was still driving it. Lucky there isn't a hole in the trans.
Here are some photos.
1969 911E SOLD
2002 996 Cabrio
1995 993 Carrera 4 SOLD
Old 12-10-2023, 08:56 AM
You do not have permissi
john70t's Avatar
New U-joint and drain line diversion?
Might also need balancing or pro examination.
2 years is not much operational time. It might be under warranty.
And tell the kid no more burnouts. What is this Cars-n-Coffee?
Old 12-10-2023, 09:34 AM
Evil Genius
Rusty Heap's Avatar
Willy Wonka would be envious of your Chocolate Factory.
Life is a big ocean to swim in.
Wag more, bark less.
Old 12-10-2023, 10:23 AM
If you can move it laterally then the bearings are shot.
Old 12-10-2023, 12:07 PM
Arizona_928's Avatar
Yeah^^
On the XYZ. Only one coordinate direction should have play. E.g. the slipe yoke having play that corresponds to the natural movement of the powertrain....
Don't skimp on u joints. Want one with the Zerk fitting(greaseable) and brand name. I use spicer.
Use a ball joint clamp style tool.
BTW that water is washing out the grease.
dolor et pavor
Copyright
Old 12-10-2023, 01:36 PM
pwd72s's Avatar
Originally Posted by Arizona_928 View Post
Yeah^^
Do they make a good synthetic grease for both U joints & Slip yokes? Just asking...
Old 12-10-2023, 02:16 PM
I like red n tacky and the Lucas green grease.
dolor et pavor
Copyright
Old 12-10-2023, 03:31 PM
Can't you just remove the shaft and drive in rear wheel drive only?
Scott
'78 SC mit Sportomatic - Sold
Old 12-10-2023, 04:43 PM
Depends on the 4wd set up.
dolor et pavor
Copyright
Old 12-10-2023, 05:57 PM
Bland
unclebilly's Avatar
In that first photo, it looks like the one u-joint is not ventured in the yoke. Might be the photo tho.
Are there u joints on the other ends of the shaft?
Old 12-11-2023, 01:26 AM
Mark up the drawing with arrows to show where it's loose/sloppy....
Old 12-11-2023, 06:26 AM
