Bill Douglas's Avatar
VW beetle question.
It's actually a 1975 Kombi and asking on behalf of the guy next door.
He said it's getting a bit hard to drive as the rev's drop too fast and the engine stalls when he is shifting down gears.
To me it sounds like a deceleration valve issue. But I wouldn't know as it's been half a lifetime since I had a VW.
What are your thoughts and thanks.
Old 02-03-2024, 06:19 PM
Tell him to release the parking brake.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 02-03-2024, 06:26 PM
LOL, that could be it!
Old 02-03-2024, 06:33 PM
Accelerator pumps in the carbs gone bad ??? I know when they get bad enough, you have to keep giving them gas by pumping the accelerator when rpm's fall.
Marv Evans
'69 911E
Old 02-03-2024, 07:23 PM
Oh, OK. I don't know about that stuff, but I'll pass the message on. Thanks.
Old 02-03-2024, 09:52 PM
id10t's Avatar
Buy him a copy of Muirs book?
Old 02-04-2024, 04:50 AM
Registered ConfUser
Along the lines of Jeff’s suggestion, make sure there’s air in the tires.
I believe WDfifteen recently restored an old VW. Maybe ping him.
Mike
Old 02-04-2024, 04:53 AM
Senior Member
Superman's Avatar
I'd say Decel Valve but I'm not sure this car has one. Unless it has an automatic transmission, then maybe. You know....one of those auto-clutch thingies.
Mocha 1978 911SC. "Coco"
Old 02-04-2024, 05:16 AM
Send a message via AIM to fintstone
probably really simple like a fuel filter or air filter...but maybe points or fouled plugs. A tune up would most likely fix it.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 02-04-2024, 07:31 AM
The engine is fine. It's one of those 1600 ones. The only problem with it is the rev's dropping to too fast when he throttles off. I don't know if he has the book. Other than this he seems to be quite good at working on it.
Old 02-04-2024, 09:35 AM
Zeke's Avatar
Low compression engines don't fall off quickly when the throttle is closed. I'd be interested in hearing it as he turned it off at idle. He should turn it over by hand. If not relatively free to turn, it's binding and maybe ready to seize.
Old 02-10-2024, 02:41 PM
wdfifteen's Avatar
I don't know much about post 1967 cars. They got too modern for me.
Don't waste money on Miur's book. Yes, it's a cult classic, but if you want to fix your own VW get the Bentley manual.
Old 02-10-2024, 05:24 PM
Another carburetion possibility could be a hole in thr float in the carb which will let the float fill with gas and not function right. That can make the rpm's drop when off throttle. If it dies without pumping the accelerator, that can be an indication.
Marv Evans
'69 911E
Old 02-10-2024, 07:02 PM
HobieMarty's Avatar
Maybe he needs this.
Wonka
Old 02-10-2024, 08:51 PM
A '75 bus would be fuel injection, in the US at least.
206 637 4071
Old 02-10-2024, 10:25 PM
Control Group
Tobra's Avatar
Check the vacuum lines
Old 02-11-2024, 05:05 AM
Thanks guys. I'll bundle up the suggestions and pass them on. Other than this deceleration problem it seems to go well.
Old 02-11-2024, 09:30 AM
