Removing muffler clamps
I have three nuts I need to remove from two clamps. They are a bit rusty. I will soak them first with liquid wrench for a couple days and then try to remove. Do I put a wrench on them and pull hard or better off putting an impact gun on them? Suggestions?
Also I have replacement clamps if needed but no bolts. if I need bolt, what do I get for muffler application.
Thanks.
Old 03-05-2024, 05:26 PM
Old 03-05-2024, 05:28 PM
Fire. Oxy-MAPP torch set up with get those off. Just get them glowing.
Old 03-05-2024, 05:48 PM
You do not have permissi
john70t's Avatar
That's too far gone. Don't bother too hard unless you have extractor sockets. IMO. Worth a try tho.
Angle grinder it down to near the surface level.
Try not to nick the clamps or bounce it into important things. Protect those with sheet metal if needed.
Or use a small thick! cutoff wheel disk and split it down the center with gentle chisel.
Center punch lightly in the center of bolt and it should pop apart.
Old 03-05-2024, 06:24 PM
I like an impact wrench.
Heat up the nuts first with a small butane torch, so the metal expands.....
Old 03-05-2024, 06:27 PM
A930Rocket's Avatar
Try PP Blaster versus liquid wrench. That said, prepare for them to break off. I’ve read somewhere start by tightening it a little bit then loosening. Then back-and-forth with lots of PB Blaster. If you have fire, that’s another good suggestion
For replacement bolts, I’d go with either galvanized or stainless steel.
Old 03-05-2024, 06:33 PM
john70t's Avatar
Never used butane.
Propane is slow and will heat the whole thing. eventually.
MAPP is better.
Acetylene with a small welding tip is precision.
When it's cherry you might be able to hammer on a slightly smaller imperial vs metric socket if it strips
Old 03-05-2024, 06:40 PM
weekend wOrrier
I had something similar on some sway bar links on a recent car.
I hate sway bar links. If you know, you know.
In the end, I hit them at an angle with a dremel to make a slot. In the slot I inserted the impact wrench (muffle splitter) and blasted it straight to hell.
The impact wrench (muffler splitter) turned the slots from my field of view.
Now I had no angle.
I cursed.
I cursed some more.
Eventually I was victorious. Over a $12 sway bar link.
The watchmaker in me was victorious. The timekeeper would have invested in FB or something and made $500k and just bought a new car.
God granted me with watchmaker genes though.
At least I am granted with something.
Good luck.
Without grinding, I think the worse case the bolts snap and I just push through and remove.
Right side clamps are all new fortunately.
Old 03-05-2024, 06:44 PM
Bill Douglas's Avatar
Too expensive for just one job, but there are these cool things that have an electric element that wraps around the nut and heats up just that part. The nut gets really hot, expands and glides off. The only catch is the price.
Old 03-05-2024, 07:45 PM
Hit them with an impact. If they come loose, cool, if they snap off thats easier than cutting them.
Old 03-05-2024, 08:58 PM
rfuerst911sc's Avatar
Those are rusty enough to say they will snap off . Hit them with an impact and be done . Buy replacement SS or galvanized bolts and use anti-seize on the threads . Always use anti-seize on exhaust parts , even a thin layer inside the clamps make future disassembly sooooooo much easier .
Old 03-06-2024, 02:11 AM
Thanks Everyone. I’ll report back.
Old 03-06-2024, 03:50 AM
This. Those induction heaters work fast and easy. I know of one muffler shop that uses them to avoid the broken bolts issue.
https://www.amazon.com/s?k=induction+heat+bolt+removal+tool&crid=2V2I5FKAGFH8O&sprefix=induction+heat+bolt+%2Caps%2C148&ref=nb_sb_ss_ts-doa-p_1_20
Yea, expensive, but a one time purchase for home mechanics.
Old 03-06-2024, 06:01 AM
I do have a propane torch. Am I okay to use where it’s a mid engine car? The motor is right there. It’s a 986 (Box).
Old 03-06-2024, 06:03 AM
It'll be legen-waitforit
stealthn's Avatar
“PP Blaster” hehehehe
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 03-06-2024, 06:25 AM
LOL .... PP Blaster IS liquid wrench!
Ya gotta get pissed off at them suckers
If ya don't have success (you will) with the suggestions offered already .... go by a muffler shop and have them remove them.
Old 03-06-2024, 06:34 AM
Counterclockwise?
First thing you need to do is take a wire brush to them.
Then the solutions above.
Rod
1986 Carrera
2001 996TT
Old 03-06-2024, 06:45 AM
Steve F's Avatar
A cut off wheel in a Dremel tool.
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 03-06-2024, 08:35 AM
Shaun @ Tru6's Avatar
MAPP ia hotter than propane and will get the nuts to glow without the oxygen bottle and special torch. What I like about my oxy-mapp is the torch head is pencil with a tiny ultrahot flame. Bernzomatic standard bottle torch head and flame is massive in comparison.
Tru6 Restoration & Design
Old 03-06-2024, 09:23 AM
