UnRegistered User
Cheap shot for sure. Don't like to see anyone take a shot like that. Not even Marchand. Think the NHL will have a look at the new angle video and sling a little justice. The vid I saw last night didn't show anything other than what looked like a solid check. Embed didn't work but the video is available through the link.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
I agree, Bennett is a POS as he’s been known to do that before.
Refs also have been very pro FL, the disparity in Power Plays is crazy. How that was not goalie interference is beyond me, easily a cross check call at a minimum negating the goal. |
I see you
Can you believe the 'Canes over the Rags last night? That was a YUGE 3rd period.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
People are arguing that 69.1 makes it a non-goal. Here is the last paragraph: If a defending player has been pushed, shoved, or fouled by an attacking player so as to cause the defending player to come into contact with his own goalkeeper, such contact shall be deemed contact initiated by the attacking player for purposes of this rule, and if necessary a penalty assessed to the attacking player and if a goal is scored it would be disallowed. But I believe the league applied rule is 69.7, which is this: 69.7 Rebounds and Loose Pucks - In a rebound situation, or where a goalkeeper and attacking player(s) are simultaneously attempting to play a loose puck, whether inside or outside the crease, incidental contact with the goalkeeper will be permitted, and any goal that is scored as a result thereof will be allowed. The goal was technically scored off a rebound, therefore 69.7 above applies, and incidental contact is permitted. The rule probably was not intended to cover that goal, it was intended to allow a struggle in the crease for a loose puck. But for now, this is the rule, and the goal was 'good'.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Counterclockwise?
Refs should be held accountable with a post game interview with the media just like everyone else.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
The punch by Bennett was almost impossible to see from the back side of the play, so it gets missed, but I do not understand how four referees missed the McDavid high-stick on Hughes (it cut his cheek, so the linesmen are allowed to call a penalty on the play). As a start, the league needs to explain the review decisions made in Toronto during the playoffs. Why was Bennett's goal ruled 'good', which rule was applied, etc. They should also disclose what plays were reviewed for subsequent punishment. (was Bennett's punch to Marchand reviewed?) I see no benefit to having referees come to the podium and say, 'I did not see it'. That will be their explanation for every missed call. Also, there is zero chance that referees will allow that to happen, their collective agreement does not require it, and it never will.
Ubi bene ibi patria
While I have no love for Marchie & I am a believer in 'you get what you give'; Bennet's cheap shot was down & out 'dirty pool'. That's the kind of crap none of us want in the game.
As far as the 'missed' high stick on Hughes - the ref whose name shall remain anonymous* is an analogue of MLB's umpire, Angel Hernandez (as inconsistent as they come) told Hughes to go to the bench as he was bleeding - the on-ice officials should/could have huddled-up & reviewed for the possibility of a major penalty for that factor alone. Calls will be missed & as per "1990C4S" - the refs, in general, do a very good job. Cheers JB *Kelly Sutherland - definitely in the lower half of the class
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke "As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras |
Kelly Sutherland fought wearing a helmet because a) it messed up his hair, and b) he wanted to be recognized.
![]() Referees can't 'review' to see what happened, but they should have called a high sticking major penalty, which does allow for a review. That's standard procedure now. For a good referee.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." Last edited by 1990C4S; 05-14-2024 at 12:00 PM.. |
Junior Member
Interesting the Bennett/Marchand occurance. Was this the passing of the torch from one POS to another? The NHL looks extremely bad by not sitting Bennett for a game or two IMO as he is a repeat offender. However, Marchand got what he deserved, karma is a dish well served here.
Watched a bit of the Edmonton/Vancouver game, the crosschecking is off the charts. Didn't know that you could crosscheck someone 4 times and knock a player down, then continue crosschecking them while they were face down on the ice with no penalty.
Remember, it's not a lie if you believe it. |
Ubi bene ibi patria
Can Marchie & Da Broons stave off elimination; will Canucks take advantage of the 'oinklers' shaky goaltending & take a stranglehold in their series? Gonna be a fun night for us hockey junkies! Cheers JB
I see you
I'm hoping the "Canes take the Rags to a game 7. There ain't nuthin' like a Cup playoff game 7.
Make Bruins Great Again
Second, I agree with you that there is no point in subjecting the refs to an inquisition after each game. They are human, they make mistakes, its part of the game. That said, there is NO EXCUSE for "Player Safety" who has the benefit of all the angles and videos to not punish Bennett. They can rule against a player even when there was no call on the ice (and have done so many times). IMO, "Player Safety" not punishing the sucker punch is a travesty and dereliction of duty. I will avoid the speculation as to why they didn't protect a player who was mugged. There are many who have their theories but it doesn't matter why. It only matters that they should be held accountable for the lack of action.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Correct, mea culpa.
One more point on referee availability. Teams make players 'available' based on good games and 'interesting' stories. We NEVER get the player that coughed up the puck for the game losing goal, we never get the goalie with a .650 save percentage, we never get the superstar held pointless for six straight games.
If the highly paid 'stars' can't face the music, why should the referees?
Ubi bene ibi patria
'oinklers' vs Canucks to night - still a 'pickum'. The Lanche are in tough in their series; no team wins 3 straight (although a possibility) against the calibre of the remaining competing squads at this stage of the play-offs. "Flat's" 'Rags' & the Canes tilt should provide plenty of fireworks. Does Rempe still figure in the mix?
Enjoy the evening Gentlemen Cheers JB
Do you have any guesses why Player Safety totally ignored the incident after having all the additional views to review and analyze?
The Rangers confirmed part of my eastern bracket. Now I need the B's to pull off a miracle and win the next two to make the Rangers/Bruins Conference final.
It looks like the Stars are the better odds versus the Avs - my pick The Canucks/Oilers? Its anybody's guess
In other news, there seems to be another penalty/no penalty call tonight which was a big help in the Rangers going from down 3-2 to up 4-3. NY fans will think it was the right call. The Canes fans?
![]() After what I've seen the last week or so, there seems to be no rhyme or reason to how goalie interference or crosscheck/roughing calls are made.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera Last edited by Por_sha911; 05-16-2024 at 06:55 PM.. |
I see you
![]() I think that's crap. But even Brad said something like "that's hockey". There was also this: https://www.msn.com/en-us/sports/nhl/bruins-brad-marchand-not-angry-at-sam-bennett-says-trying-to-hurt-opponents-is-part-of-playoff-hockey/ar-BB1mw8wU But I don't see a direct quote from Marchand saying that players deliberately try to hurt others.
Watching the hit live I knew Marchand was hit in the head, I just couldn't see how. I watched it over and over, at least ten times before I saw the punch. From the from side it's extremely hard to see, from the back side it's obvious. I suspect that complaints/requests for reviews from the affected team are the starting point for most DOPS reviews, and from concussion protocol removals. Marchand was not removed from the game, so no complaint from the Bruins, nothing from Marchand, means 'carry on'. Quote:
https://www.sportsnet.ca/nhl/article/bruins-brad-marchand-returns-to-practice-ahead-of-game-6-vs-panthers/ I think in this context Marchand means 'remove from the series' or 'make them less effective', not 'maim for life'. Bennet's intent is unknown. Defend? Injure? Protect his broken finger? Who knows? And who cares? He plays very hard, you should never be surprised when he crosses the line.
