Bolt size, so I know.
Book says bolt mounting bolt is m10x28. I order tap and die and they say 10x28. Bolt much bigger than tap, like 2x the size. Tap says 10x28 on it. Can 10x28 have different meanings. Thanks
From earlier question, friend found me replacement bolt, seat now installed. |
unsafe at any speed
M10 is 10 mm. a 10 machine screw is quite small. like used to hold receptacle cover on the wall. also. I think the 28 is the length. a metric thread pitch is listed as threads per mm. like 1.25.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 Last edited by wswartzwel; 05-24-2024 at 05:19 AM.. |
Thanks, I was thinking the 28 was some strange pitch. I guess they are torx bolts which use a E12.
What?
10-28 is machine screw in imperial size. M10x28 is metric and is 10mm x 28mm long. So pretty close to 7/16" x a little over 1" long.
________________________________________ Eric Hahl 85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD) 2015 981 Cayman S (Sold) 23 Outback Wilderness & 23 BMW R1250GS |
good to know the pitch for m10 before ordering tap it will be 1.5mm or 1.25mm I think
Most likely the course pitch but good to verity.
84 930 18 Cayman GTS |
He should just order a complete metric tap and die set which will have little flip out pitch measuring tool.
Tru6 Restoration & Design |
Counterclockwise?
I use those more than the taps themselves.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
