Bolt size, so I know.
Book says bolt mounting bolt is m10x28. I order tap and die and they say 10x28. Bolt much bigger than tap, like 2x the size. Tap says 10x28 on it. Can 10x28 have different meanings. Thanks
From earlier question, friend found me replacement bolt, seat now installed.
Old 05-24-2024, 05:10 AM
unsafe at any speed
wswartzwel's Avatar
M10 is 10 mm. a 10 machine screw is quite small. like used to hold receptacle cover on the wall. also. I think the 28 is the length. a metric thread pitch is listed as threads per mm. like 1.25.
Bill Swartzwelder
Old 05-24-2024, 05:15 AM
Thanks, I was thinking the 28 was some strange pitch. I guess they are torx bolts which use a E12.
Old 05-24-2024, 07:23 AM
What?
Eric Hahl's Avatar
10-28 is machine screw in imperial size. M10x28 is metric and is 10mm x 28mm long. So pretty close to 7/16" x a little over 1" long.
________________________________________
Eric Hahl
85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD)
2015 981 Cayman S (Sold)
23 Outback Wilderness & 23 BMW R1250GS
Old 05-24-2024, 08:19 AM
good to know the pitch for m10 before ordering tap it will be 1.5mm or 1.25mm I think
Most likely the course pitch but good to verity.
07 Exige S
Old 05-24-2024, 08:43 AM
Old 05-24-2024, 09:39 AM
Shaun @ Tru6's Avatar
He should just order a complete metric tap and die set which will have little flip out pitch measuring tool.
Tru6 Restoration & Design
Old 05-24-2024, 10:35 AM
Counterclockwise?
I use those more than the taps themselves.
Rod
1986 Carrera
2001 996TT
Old 05-24-2024, 11:58 AM
