Southern Class & Sass
I'm voting this most plausible. It's also most pertinent. It doesn't matter what it was for. Rip it out.
Dixie Bradenton, FL 2013 Camaro ZL1 |
Can't. See post below. |
Thanks for everyone's suggestions. An update...it is indeed an old abandoned well. Called the township and they verified it was abandoned in 98 when the new well was drilled.
As for why it is so tall, code (or township rules) dictates it has to be capped 24" above grade within 100' of the well. Because this sits in a low spot, it had to be up in the air to get above that code. So I can't remove it. Probably good I didn't just take a jackhammer to it. But now this is going to be a hassle to work around when all these crap trees get taken down. |
Push come to shove you could always cut it off a few inches above grade....do the tree work....and then re-attach using some kind of coupling.
Old dog....new tricks..... |
Use the trees to build a small log cabin around it. You're going to cut them down so might as well not have to haul them away that far.
Scott '78 SC mit Sportomatic - Sold |
Was it a well for water? Around these parts, old wells usually get filled in.
"A little nonsense now and then is relished by the wisest men." Wonka |
Preferred pronoun:Maestro
Maybe this young lady can confirm whether or not it's an abandoned well ...
When in doubt, use overwhelming force. |
weekend wOrrier
I think it's TABS' secret bunker.
Pull the top off, yell down the pipe, and see if he answers.
100% narcissist |
Platinum Member
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
From michigan.gov: "If a well is going to be used in the future, but is temporarily taken out of service at the time a replacement well is installed, it must be securely sealed and must comply with all current isolation and construction requirements." |
Most wells do not "go bad" so doesn't make any sense to destroy it. At some point someone may want to try using it again. It certainly doesn't pose any threat to the planet, as long as it remains capped.
I had forgotten about the height codes, so that explains that part of it. IIRC the code here is 24" above grade and must have a back flow prevention valve installed. I also forgot that wells are usually marked on surveys....so there's another potential resource for identification purposes.
Bland
Actually the correct way to abandon a well is to set a packer (bridge plug) then put 30’ of cement (not concrete) on top, then pressure test after 24 hours, then fill with inhibited water (anti corrosion), then cut and cap 6’ below surface, then back fill.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
