Originally Posted by LWJ View Post
I vote to fix your saw.
A saw that runs well is a pleasure to use. Worth some effort to fix it.
Old 10-28-2024, 07:45 AM
Spark arrestor screen is clean due to little use. I am tempted to just remove the fuel filter to test it. It has fresh fuel. I always put away small engines with fuel drained. Only fuel in a can is used. I think all fuels in CA has ethanol mixed into it. Will play with it some more later today.
Old 10-28-2024, 08:57 AM
How old is the fuel in the can? If it has Evilnol ... I'd go batteries
Old 10-28-2024, 09:29 AM
3 months
Old 10-28-2024, 09:53 AM
Brew Master
cabmandone's Avatar
Something that might help if you have the carb tool is turning the high side screw in and counting the turns to bottom out. Once you know how far from bottomed out it is back it all the way out and act like you're trying to start it. Sometimes if there's a little debris it will clear. Once you've done that, bottom it out and then back it out the number of turns you counted.
Nick
Old 10-28-2024, 04:47 PM
Great idea, thanks
Old 10-29-2024, 08:39 AM
Platinum Member
dad911's Avatar
Change the fuel lines. Alcohol in gas screws them up.
Old 10-29-2024, 10:07 AM
^^^ Got it, thanks
Old 10-29-2024, 02:40 PM
Ok, so I back off the high screw and it seems to run OK, a no more bogging at full throttle but not smooth like it was. After full throttle for about 3-4 min, it go hot, so hot that the plastic cover started to melt (pic where it say Echo). It smoked about 30 second of running it. I was thinking oil but that cover there got super hot and I can't touch it. Tips?
Smoke is coming from behind that cover. I have to open it up to see but its too hot now.
Noticed the oil, it dripped that much jsut from 3-4 min of running with the chain disengaged. Oil is only at 15-20% to full.
Old 10-30-2024, 05:48 PM
Just to clarify.....you held the throttle trigger all the way in for 3-4 minutes straight?
And while not doing any cutting?
Just WOT for 3-4 minutes straight?
Thanks!
Old 10-30-2024, 06:09 PM
Thanks!
Yes, chain was not engaged or not turning
Old 10-30-2024, 06:28 PM
You just burnt up the clutch. Probably melted the housing too thats why all the oil is leaking out. I got a brand new stihl at tthe curb somebody did that to. It took some doing to fix all the damage
Old 10-30-2024, 06:52 PM
908/930's Avatar
Full throttle with the chain brake on? And it got hot, lol. Don't do that.
Old 10-30-2024, 06:58 PM
Oh siht, is that that thing is, a brake? I thought it engages a clutch or something that keeps the chain off the gears to keep it from turning the chain. Did I screwed something up? Now the damn oil, I have to find out what to do about it dripping so much
Old 10-30-2024, 07:46 PM
908/930's Avatar
Lol, pretty sure it is a brake. Not sure what if any damage it would do, should be pretty easy to remove the cover and check on the clutch, pretty sure there is a bearing in there somewhere that could use some grease now. Is there an adjustment screw for chain oil delivery on that saw?
Old 10-30-2024, 08:35 PM
greglepore's Avatar
Lucky it didn't catch fire. Yeah, that's a chain brake-designed so if saw kicks back there's a chance the hand guard gets hit and it stop the chain before it opens up your face and forehead. Ooops.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 10-31-2024, 05:28 AM
Glad I learned something at someone else's expense....
Old 10-31-2024, 06:37 AM
Counterclockwise?
Now you know it's not the carb (anymore)
Rod
1986 Carrera
2001 996TT
Old 10-31-2024, 06:42 AM
The large plastic rectangular handle on top of the machine is the "brake". Moving it forward or backwards will release it - or set it. It's a safety feature.
If you take the side cover off, there's a metal band that will engage on the flywheel when the brake is engaged. Running the saw with the metal band engaged on the metal wheel is what did the melting from the friction creating heat.
I had to replace one many years ago, so it may be repairable, unless it will still work.
Old 10-31-2024, 07:13 AM
wdfifteen's Avatar
The "metal wheel" that that brake band contracts around is the centrifugal clutch drum. The cog that drives the chain is usually a permanent part of the drum on small saws. It is a wear item, so it often gets replaced and ought to be readily available. The clutch shoes inside the drum might be roasted from the heat. The heat may also have roasted a rubber oil line for the chain oiler, and that might be the source of the oil. Check YouTube University for a video on how to change the clutch on that saw.
Repairing it CAN be a DIY project, but there are so many items that could have been damaged that I would turn it over to someone with experience with these saws.
Old 10-31-2024, 08:45 AM
