Help me find a Cayenne pepper ...
wagon ... methinks.
I have decide, spur of the moment, that I must have one... don't ask !I've read they are bargains ... just want a good reliable SUV and they look cool ... for one of those.... No performance enhancements needed ... it'll be a taxi.... IT MUST NOT BE WHITE! The older the better .... for a good one ... yep! Thanks a bunch .... I'll start my quest later on, but since we have Mattbots here ... why not here ![]() Thanks! I am a racist
Did you get the memo?
I’m going to create a bot that helps people shop for cars, like the Carfox but not a fraud.
![]() You said older the better, what model are you looking at? Price range? Tim Hancock swears by the V6 base models, I’m partial to the V8 and have owned a 955 GTS that was quite good for an SUV. Any particular features you want? The PASM air suspension is really good and provides a lot of adjustability, but obviously that’s more stuff to break too. This is one where I would definitely be looking private party only, and want something with service records. They can be good trucks if kept up on.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
I just hit 165K miles on '10 GTS. It has been very reliable but I don't think they have that reputation in general. A Lexus would be a better choice for a taxi. But if you need a Cayenne, get a 2008-2010 base model with a V6. The key is a file folder of owner repair records and a good PPI.
These things are the new 944/928 of years gone by, purchased by people who couldn't afford to fix them, so buy the best one you can find from an original or second owner. I have said over and over here, a 957 GTS is the best "if I could only have one car" vehicle ever made. By far.
Tru6 Restoration & Design |
If you live anywhere that gets snow or have the need to haul bigger stuff I would 100% agree with Shaun. I’m partial to a good sports sedan, but the Cayenne does a pretty good sports sedan impression with some additional practical advantages.
The only big thing I’m aware of with the early V8 models are the plastic cooling pipes that tended to crack and were later upgraded to metal. Here’s a good DIY write up. Otherwise it’s mostly what I would call typical German car stuff for upkeep.
https://blog.ecstuning.com/how-to-replace-or-upgrade-your-porsche-cayenne-s-or-cayenne-turbo-coolant-pipe/
Counterclockwise?
I thought some had engine failure?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Just a quick update .... I have not searched for anything yet... a 6 cyl Cayenne or Lexus 350 will work ... non-white.
A taxi for my parents ... easy to ingress/egress and I don't like the Highlander that I bought for mom ... and she might drive it a bit more ... still. So an older version of either... ideally, it would have belonged to Matt for years and years ...Thanks! |
It’s getting in and out is an issue and you want to go with the Cayenne I would definitely get the air suspension model. It’s more complex and more things to break but you can lower the truck way way down so it’s like getting into a Ferrari. |
Zink Racer
I wouldn't eliminate looking at a dealership for a good used one. We bought our Macan S that way and negotiated the CPO warranty into the deal. I know I paid more than private party, but ours was owned by a meticulous wealthy couple who cycled through new ones every 4 years. It had higher miles, but was spotless and had all services done. We've now had it for 5 1/2 years and since my wife retired, it is babied and driven under 5k miles per year.
Jerry 1983 911 SC/Carrera Franken car, 1974 914 Bumblebee, 1970 914-4, 1999 323ti |
I don’t think many of the base V6 models will have the air suspension. CPO with full dealer documentation would be good but I don’t know if Porsche will even CPO something that old.
MAGA
About 240k now on my '08 6 cylinder. Have only had to fix a few items for the 100k plus miles I have owned it.
Had trans valve chest rebuilt after initial purchase 130k ish due to hard shift in a gear or two... high pressure fuel pump at around 190k.... Replaced one radiator fan at about 190k... replaced original battery about 2 years ago... repaired one flex pipe near exhaust manifold at about 200k... Replaced air/oil separator at about 225k Maintenance wise. Oil changes, Transfer case oil change a couple times with Ravenol, Trans fluid change once... due again soon. Brake pads and rotors changed twice over entire ownership. Just recently changed front and rear original diff oil and replaced all 4 original shocks/springs with cheap aftermarket, lifted it a couple inches and added new larger tires. It is my daily driver for work and with the new tires and shocks, I recently made the decision to continue driving it for several more years vs dumping it for something newer. Still drives nice and interior is still nice looking although I now have a few small door dings and car could use a good buffing session. ![]() Wife's 2013 6 cylinder Cayenne has a bit over 100k and has been trouble free so far with only work being tires and brake pads once.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Sounds perfect Tim ... just name yer price for either one ... I have rattlecan paint too
!Air suspension, etc. don't want or need ... cars are an issue .... too low. Is cargooroos still a decent search site .... any others? Last edited by KFC911; 12-17-2024 at 10:11 AM.. |
MAGA
Neither are for sale... Wife's '13 is our newest "good" car but should last several more years before she starts jonesing for a newer one. She will likely retire next year so daily mileage will drop off considerably. I really like our older simpler cars we buy used with cash... Someday I will be faced with having to buy the newer overworked turboed small motored cars with crappy CVT transmissions and overly complex electrical/fuel systems that will be more difficult to DIY maintain/repair. Damn CAFE standards, safety regulations and unwanted tech features.
Cars and Cappuccino
Get a 2015 or '16 diesel. My '16 is under warranty until Dec. 2026. Tows like a champ and gets 32 mpg on the highway.
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
As a close plan B, I have a bulletproof 2011 Lexus RX350 that may be up for sale in Jan. Alas, it is indeed white.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
Everything is for sale for a price. Since KC prints his own money....
Walmart has em.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI Last edited by stevej37; 12-17-2024 at 12:22 PM.. |
For searching look at Cargurus, Autotrader, Cars.com, EBay, Craigslist, and Facebook Marketplace if you’re a Facebook guy. If you’re looking for one with or without air suspension, look between the shifter and cup holders on the console, right side. Air suspension has a control panel for height and handling mode, non air suspension will have a small coin tray.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc Last edited by onewhippedpuppy; 12-17-2024 at 12:39 PM.. |
MAGA
I recently bought a complete new set of assembled front and rear struts with new springs for $260 on Ebay for my '08 non air suspension Cayenne. I shudder to think what air shocks and air suspension components would cost to replace.
Am guessing the air suspension Cayennes work just fine, but I like not having to worry about it on my high mileage cars.
I am constantly amazed at how inexpensive part are for the truck.
