Author of "101 Projects"
Electrical Pool Lights wiring question...
I posted this on www.electriciantalk.com but those parsimonious twits said, "hire a professional" and then deleted / locked my post. What aholes.
So maybe someone here can give me some feedback on this. I do actually want to hire a "professional", but I don't trust anyone these days, particularly when "professionals" make mistakes that kill kids (as seen in Florida). Thanks in advance. Quote:
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Personally, I think that's overkill - so long as you don't terminate the 12v wiring inside the j box. All of the dc wiring should run thru the box to the xformer in its original sheathed cable, and the sheathing doesn't get removed until its clear of the 120v stuff. Your conduit to the lights likely terminates in the existing j box, so to completely separate out the wiring you'd need to put s bends in the conduit to relocate its termination.
Having the sheathed cable pass thru the existing box to an external location for the xformer is safe enough for me. This assume appropriate gfci and pool bonding, which is necessary regardless. Not a pro, but I've done a fair amount of pool and spa maint...
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Hmm. This gives some good thoughts - I should post a pic. Separating the 12 v from the 120 junction box shouldn’t be too difficult - there are individual conduit pipes coming up from the ground. I can just tap on to the existing conduit and then run the 12 directly to the transformer or to an additional “12 v only” junction box.
Wayne |
Retired from the swimming pool industry and never made a transition from 120VAC lighting to 12vdc lighting but... Best practices with lighting, audio, and machinery always suggest physical separation of 120VAC and 12vdc circuits. I would not connect them in the same J-box but I would still have a bond wire from the underwater fixture connected to everything else (bond wire is different than green ground wire).
This is the current Florida Code for submerged luminaries and it appears that a bond or ground is not required. The J-box for 12vdc does require separation from 120VAC circuits. I hope this is helpful. Pentair tech support line also used to be very helpful when you hit a snag like this. Cheers! https://floridabuilding.org/fbc/thecode/2017_Code_Development/2017_Resources/Swimming%20Pool%20Electrical%20Safety%20-%20fact%20sheet%20-%202016-06-30.pdf
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) Last edited by Cajundaddy; 12-26-2024 at 12:11 PM.. |
Yeah, I agree that separating them isn't all that difficult, but once you do that you'll have a 90 or worse an s bend in the conduit - if and when you replace something you have to pull the cable thru that, which while doable isn't fun or optimal. A pic would help, but I'm envisioning that you have a large 120v box with 3 120v light cables tied to one 120v switch source for the lighting, and a separate 120v switched feed tied to the cable running to your power cover. So 5 or 6 conduits - one or two for the 120v in 4 for the 120v out to lights and motor?
As above, the bond is important and different, don't disturb it when you working in the light niches. It should be number 8 copper tied to anything metal in or around the pool-its to ground out stray current that can exist independent of the pool circuitry .
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) Last edited by greglepore; 12-26-2024 at 11:53 AM.. |
Now that I think about it the 12v cable is likely much small dia. than the 120 so probably very easy to pull thru a bend....
The place to ask for sure is troublefreepool. Its the Pelican of diy pool sites, and a fair number of pros post.
Sorry, the iPhone got confused. I'm not at the house right now, so I can't take a "real" photo.
I think if i simply cut the conduit for the pool lamps short, then I can can simply add on a flexible conduit and run it over to the wall where the 12V transformer will be? That way, the 12V wires and the 120V wires will never be in the same junction box, and never have a chance to "commingle". I know that a few of you said that if I simply run the 12V through the box and do not terminate in the box, then I should be okay, but if there is a deterioration of the sheath or something odd (like a mouse chewing stuff), then there is indeed a chance that they can connect. Very slim, but we're not talking about blown equipment - we're talking about pool lights which can easily kill people? -Wayne
-Wayne
What about just separating into two J-boxes. One for low voltage and one for 120VAC so they are completely discrete? It might take an hour to separate them but you will be 100% certain of the result. This should also keep the inspector happy while cutting the conduit may not. Best wishes!
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) Last edited by Cajundaddy; 12-26-2024 at 10:02 PM.. |
Feelin' Solexy
I am not going to be of any help re: your actual question. But, I believe I recall you (pretty sure it was you Wayne but possible I am misremembering) having a thread several years back where you were sealing up your swimming pool with a flush wooden deck. If I am not misrembering, is this the same pool/how did it all go recommissioning the pool/any regrets or lessons learned from the deck approach?
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
