Throw it on the ground!
What's your go to method for removed seized bolts?
So I purchased a used set of 20" wheels on Facebook Marketplace for the Jeep as it's time to buy new tires. Will be painting the decorative plastic spokes and star center caps body color grey. Found a new spare on Facebook as well in the size I'll be going with (35"). In getting it mounted, I found that 4 out of 25 allen head bolts were seized so I had to drill them out and extract them with a reverse drill/extracter kit which was a real PITA. I anticipate all of the other wheels will have as many or more siezed bolts so I bought 10 addl drill bits.
I sprayed the bolts with PB Blaster and tapped the allent key socket with a hammer but did not use a torch over concern of ruining the finish of the powder coat finish. Suggestions welcomed. Thanks! ![]() ![]()
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
This stuff is the hot ticket!
https://www.oreillyauto.com/detail/c/kroil/kroil-penetrant/krl0/ks102?q=ks102&pos=0&_hsenc=p2ANqtz-_L8uV_Y5jY7p2AApPszd-0HjmL6Z7-enJHYN1r5OrfRyCfllTrxqYmH1btejl626tFeebAcy6zYnHShK m6ygTbiCipoQ&_hsmi=343645401
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
1/2 acetone. 1/2 ATF. I read a study by an Engineering school where this outperformed all penetrating oils. I believe it. It works very very well. Hammer + heat gives this stuff a 100% score for everything I have used it on.
Parrothead member
I have two friends that are heavy equipment mechanics. Both swear by the acetone/atf thing. Won't use anything else. I've tried it a couple times. Seems to work. My normal go to is PB or liquid Wrench. All I know is WD40 is the worst. Kroil is great but $$.
One method that I use is, I'll use an impact wrench on its lowest setting, give it a few taps n either direction let it sit awhile, then over time, gradually crank it up to a higher force. .
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
^ The acetone/ATF mixture works well!
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
I am almost exclusively a fire person.
Tru6 Restoration & Design |
To answer the question posed in the thread title, Sell the vehicle.
Right, destroy the vehicle with fire. A little more extreme than selling, but certainly a valid option especially if you drilled the bolt and then broke the easy-out off in the hole. THen it's completely understandable.
LOL! You are a smart fella!
Damn. Imagine being roadside and having that same issue.
poof! gone |
Yep..it's the wheels themselves that I question. What's the purpose of those add on pieces? Just look like traps to pick up mud & debris to me...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Keep talking, Im gonna put you in the trunk. |
Banned
pointless covers get tossed out of my garage.
id drill em, and then never reinstall. |
Good point. What a nightmare that would be. I could see using a sledgehammer to "fix the glitch" if I was on the side of the road with a flat in the hot sun and I couldn't get the "hub caps" off. Hell, if I was on the side of the road in the heat with a flat and had to use an allen wrench to get to the lug nuts, I'd probably be pretty grumpy.
I think they are supposed to look "tough". The current fad of busy wheels for trucks is not my cup of tea.
Parrothead member
I have the same type of covers on my dually wheels. I have to take them off to get at my locking hubs. Every now and then I'll break them loose and give them a few turns so they don't freeze up.
Model Citizen
Vinny, I had a similar situation with my locking hubs. I eventually took a hole saw - which was luckily the perfect size - to very carefully remove the center of the caps.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
At least you could still get to your luck nuts!
Registered ConfUser
A liberal coating of anti-seize when reinstalling....then loosen and retighten a few times/year. Or toss 'em as already suggested.
Mike “I wouldn’t want to live under the conditions a person could get used to”. -My paternal grandmother having immigrated to America shortly before WWll. |
First, I use good quality, tight-fitting tool. In this particular case, I use regular Snap-On sockets but I think there are more modern designs that are better.
Smack the inserted tool with a hammer, many times. I use heat from a heat gun and candle wax or crayon, as many times as necessary. When I have needed to protect something adjacent, I've fabbed up some heat guards to keep the heat only where I want it. For something like an allen head bolt, you could also use a micro torch in the center of the recess. I have no idea about those wheels but sometimes the holes go all the way through and your penetrate of choice can be applied to the back side.
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle |
