Inexpensive occasional use bench grinder?
Anyone get any recommendation for an occasional use bench grinder? It'll mostly get used to sharpen mower blades, but I'm sure that there will be other occasional uses for it.
So, 6" or 8", HF or someone else? ![]()
I have a 50 year old Craftsman bench grinder that I think was my Dad's fathers.
I used it a lot when we got here 30 years ago, but now I frankly only sharpen mower blades or but put on the other wheels (like buffers) for specific stuff. It is not variable speed so I can't help you there. I use it maybe 10 hours a year. Me? I'd get the 8" Bauer with the light if the reviews are good. The light really helps.
1996 FJ80. Last edited by Seahawk; 05-05-2025 at 01:03 PM.. |
Counterclockwise?
I'm into old bench grinders.
They are twice the machines as the ones in your pictures and less than 1/2 the price.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
The problem with that is that I live in BFE, so there aren't people out here selling any. And if I went into Houston or a suburb looking for an old one, all of the FB MP ads for any sort of tool seems to be at full retail price, and/or is someplace that's an hours (or more) drive away.
I have that $50 wen grinder mounted to a 2x6. I clamp it down on the bench when I need it.
I pretty much only use it to sharpen mower blades and it’s fine for that. |
Did you get the memo?
I’d go HF all day long and be happy. Honestly their quality is equal or better to most big box store brands.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Friend of Warren
Since I got a Bauer harbor freight cordless angle grinder and 4 inch flap discs I don’t remember the last time I’ve used my grinder. It’s a lot easier to sharpen mower blades, chisels, etc. by putting them in my vice and using the flap discs. And those discs are cheap and seem to last forever.
Kurt V No more Porsches, but a revolving number of motorcycles. |
If your main use is sharpening steel, a larger wheel that turns slower is your best bet to prevent overheating. 8” and 1,750 is usually considered a good grinder for sharpening.
Rutager West 1977 911S Targa Chocolate Brown |
Brew Master
I use an angle grinder for blade sharpening. To me, it's WAY easier than using my 8" bench grinder.
Nick Last edited by cabmandone; 05-09-2025 at 05:07 AM.. |
A good sharp file will sharpen a lawn mower blade better than a bench grinder with about the same time and effort.
I have a bench grinder similar to those pictured above but have only used it a few times in 10 years. I was sure I needed it when I bought it but that did not turn out to be the case. |
I used to have a small portable grinder, and never used it. My other was, I'm pretty sure an old 8" model that had a 4" sanding belt on the other side. That was nice and got used from time to time.
Model Citizen
A flap disc on an angle grinder is my go to.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
I'd be looking at FB MP or Crglist for something old but local.
Lots of them at garage sales, etc that are much better then new from HF if you ask me.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
I have some ancient low quality grinder. It works great.
I would advise to check out craigslist or similar and buy one for pennies. |
Yep, mine is also an old Sears Craftsman that I use for sharpening blades, rounding off cut corners, and wire wheel to remove rust. Single speed, plenty of torque, bulletproof. They can probably be found used for $20 on FB MP.
No opinion on the new ones.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
Model Citizen
You might get lucky on CL or FBMP and find an old Sears block grinder, for cheap, but they have a big fan club and most owners 'know what they have', so to speak.
But the big problem is that anything that I try to buy from Houston will end up being a 1-2hour drive (one way). That's what I had was some good old stuff, and I wish I still had it, but the odds of me running across it are slim to none around here.
A bit more expensive, but if you’re just doing mower blades, something like this might be a better choice.
https://www.vevor.com/bench-grinder-c_11010/vevor-lawn-mower-blade-sharpener-2-3hp-500w-with-7-inch-ceramic-grinding-wheel-p_010770163297?adp=gmc&utm_source=google&utm_medium=cpc&utm_id=20922352686&ad_group=152802351250&ad_id=687107254260&utm_term=&gad_source=1&gad_campaignid=20922352686&gbraid=0AAAAACq8bLVfK3Zku7kBLGt4tS5Fkzbhn&gclid=Cj0KCQjww-HABhCGARIsALLO6XxE0ATI4Yjlz6Ief-DtMu59J5y3PSYvOPFyxlNVb-xJe4qBEveW_2kaAsPkEALw_wcB
I use an angle grinder for mower blades then finish with a flap wheel. But as for a bench grinder I fabricate and use one almost every day. I have a grinding wheel on one side and wire wheel on the other. The one i mainly use is a delta 6" I like it because its not that strong. If I get something snagged horribly it will stop. My other craftsman one is stronger and one must be more careful with it. So dont feel like you must get a big one because you might find yourself avoiding using it
82 SC , 72 914 |
