Southern Class & Sass
Help me with this half-baked jalousie window idea
I'd like to make the old jalousie windows in my kitchen a bit more energy efficient. I'm thinking maybe I could put some kind of clear plastic on the window screen frame, and shrink it smooth with a hair dryer? The screening is on the inside, it's aluminum, and attaches via clips that screw into the window.
Dixie Bradenton, FL 2013 Camaro ZL1 |
Maybe some sort of storm window (inside or outside) to create an additional layer. Or get some lexan/acrylic sheet from one of the big box hardware stores to try a DIY option like you're talking about.
It would need to be a really tight seal as air tight as you can get it. Maybe put a light tint on it too.
Counterclockwise?
You can buy shrink film kits here that you apply with 2 sided tape and then shrink them with a hair dryer. Usually used to keep the cold out, but would work for you as well.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Navin Johnson
My house used to have Jalousie windows...before I replaced them all I used shrink film to seal the windows for the winters here.. I still happen to have one of the kits laying around.. You'd probably have to buy from Amazon, s I doubt a FLA Home Depot would stock this.
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Dixie find a local shop that can make a simple aluminum framed window . With all the sunrooms down there this should be easy . A simple aluminum frame with a piece of lexan in it . Strong and lightweight. The tricky part is how to mount it so it's easily removable when you want ventilation . Much better than the window shrink film . The shrink film does work , but the two sided tape is a pain to remove .
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
You can build with aluminum shower door frame material and plexiglass or marine vinyl.
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
This is what I was suggesting . In Florida you should be able to find it in mill finish , white , bronze and maybe other colors . Cut the frame to size of lexan , mitre the corners and push the frame over the plexiglass. Boom done
![]() https://www.amazon.com/CRL-Sash-Universal-Storm-Window-Frame/dp/B000KZXE58/ref=asc_df_B000KZXE58?mcid=a3eb6c809e593159a4fc946 38db8ad64&hvocijid=7715844229871881054-B000KZXE58-&hvexpln=73&tag=hyprod-20&linkCode=df0&hvadid=721245378154&hvpos=&hvnetw=g&hvrand=7715844229871881054&hvpone=&hvptwo=&hvqmt=&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=9011027&hvtargid=pla-2281435177618&psc=1
Leadfoot Geezer
How important is getting some fresh air in the kitchen thru those windows? Any sort of permanent or semi-permanent cover will prohibit that. In the long run, replacing the windows might be worth considering...and it may not be that big of a job. Have a window place come out and take a look.
On a side note, I once lived in a house with some jalousie windows that was ransacked and robbed. The thief didn't even have to break anything to get in...just simply removed the individual glass panes from one of those windows from the outside and climbed right in. Maybe another reason to think about replacement...
'67 912, '70 911T, '81 911SC, '89 3.2 Targa - all sold before prices went crazy '25 BMW 230i coupe - current DD '67 VW Karmann Ghia convt. & '63 VW Beetle ragtop - ongoing projects |
It's not important at all. I suspect they were last opened in 1957. The challenge with replacing windows in a 100 year old Florida house is dealing with what else you find. Actually, it's more like what you don't find, like intact studs.
Dixie Bradenton, FL 2013 Camaro ZL1 Last edited by Dixie; 06-10-2025 at 12:35 PM.. |
There are windows that just get installed into the old window frame. Company measures them and the get custom made and then your window guts are removed except the frame and the new one is installed. No messing with the structure of the house.
I know this is fairly common on double hung windows, but not sure about your style.
Rutager West 1977 911S Targa Chocolate Brown |
When we had our old aluminum sash windows replaced with double paned ones, they didn't do anything to the existing frames except cut the protruding flanges off from the sides. New windows slid right in.
It will make the kitchen a lot more pleasant to be in if you can look out the window with glass instead of plastic film.
Scott '78 SC mit Sportomatic - Sold |
Home of the Whopper
Curtain.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
Here is my quick and easy idea.
Measure dimensions inside window frame, have a plastic shop like TAP Plastic make a pane of acrylic or lexan cut to 1/2” smaller dimension, maybe tinted, thickness just enough that it’s not super floppy. Get some of that split foam insulation for water pipes, ideally white color, run it around the pane, and press the insulation-bordered pane into the window frame. The insulation will compress to fit into the 1/4” space on each side and hold the whole thing in the frame. (Maybe go look at a piece of the split foam and make sure 1/4” is right -squeeze it to make sure it will compress down to 1/4” thickness easily enough). You might have the shop drill a little hole in the pane, you can put a piece of cord through the hole and knot it on both sides. That gives you something to grab when you are trying to remove the thing. Should be cheap, easy to install and remove, and keep the look of the jalousie windows which are kinda retro cool for your location.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? Last edited by jyl; 06-10-2025 at 06:43 PM.. |
Assume for heat?
Try a reflective film before putting any actual effort in. |
There is a company in Oregon that makes inside storm windows exactly as you are thinking.
It is a low cost product that this particular company charges Cadillac prices for. I have seen first hand how they manufacture and run the company and am not impressed. But, I see the draw for this sort of product. An air gap and stopping air infiltration will significantly improve your thermal efficiency. I suspect there is someone in FL that can do this. |
Almost Banned Once
Have you considered this? Search "DIY Double glazing kit".
The inner window is held in place with magnets.
- Peter |
disband
Pull the cranks out..... They seem to be aluminum, so they are likely not rusted... They may just be a bit cranky.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Platinum Member
Shower door 'guy' can cut glass and get it tempered. My guess about $200.
Measure to fit with the jalousie hardware removed, and caulk it in with a good silicone caulk.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Half-baked? Leave it in the oven longer, just don't put it in your air fryer!!!
"A little nonsense now and then is relished by the wisest men." Wonka |
If you want to go all in, I saw a house that someone had wrapped the entire thing with a thick plastic wrap, only cutting a hole for the doors. It isn't the most attractive solution, but I'll bet they didn't feel the wind coming through the walls anymore. |
