Team California
No thanks, amigo.
Denis |
No muss, no fuss....
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
Did you get the memo?
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Double Trouble
914-easy
Cayenne- PITA
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Team California
Denis |
What's hard about the Cayenne? I like that you don't need a jack.
Tru6 Restoration & Design |
Team California
I just had a really unpleasant time doing an oil change on this little R53 Mini Cooper. Had a heck of a time getting the oil filter canister to thread back on because it's a weird angle and you're doing it blind down a narrow passage. I finally disconnected the strut bar and lifted it out of the way and got it. (Duh).
One of the guys I share the space with, (not a mechanic), thought I was hurt and needed help because of the profanity I would unleash every time I burned my hands on the hot exhaust shield next to the oil filter location. "Are you ok?" Me: "I'm always ok, I just swear a lot. If you ever hear me yelling, 'HELP!' you can come running. Otherwise, ignore me." ![]()
Denis |
Team California
Thanks! I'll look into those.
Denis |
The 72 911 specifically is not "hard" but it's not "fun". Even with a Fumoto valve and a tube the 72 unique tank location makes it a pain in the butt to get to the tank opening behind the rear wheel. I've been changing oil on aircooled 911s for 30y and I still make a mess each time, one way or another. The one time I almost had a perfect spotless change I kicked a dirty oil can by accident and spilled, LOL...
The BMW2002 Oil filter location is also a complete $%$#%#$% and super hard to unscrew (or put a wrench on). I don't think I ever had an "easy" car for oil + filter.. Even old VWs and 356 would sometimes mess with your day pulling a stud from the oil filter plate.. if you can call that a filter ;-) |
Old dog....new tricks..... |
I don't have a lift :^(
My tundra and jeep are a pleasure compared to my 911 and wrx. I've always raised my trucks and lowered my sports cars. The trucks are high enough to slide a 5 gal. bucket under to catch oil and my arms are free even on a creeper. I have to ramp up my sports cars to even access the drain plugs and forget about a creeper, I'm slithering on my back. |
I don't have a lift either. These ramps help a lot!
Team California
I use ramps sometimes but the OCD in me always wants to raise the rear of the vehicle and see if more comes out when it's level.
Denis |
Easiest = My 2024 Toyota Tacoma Off Road.
Hardest = Porsche 2017 and newer 718 Caymans. The filter is in an evil place!
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
I most resent that you have to buy a special tool to reset the maintenance. Completely egregious of Porsche not to build it into the cars HMI. Also really sucks to not include a center jack point. Would make maintenance 200% easier. Germans just don't care about making maintance coinvent I think.
84 930 18 Cayman GTS |
Retired Member
My old SC was easy, removing the filter could be a little messy.
My Tahoe is easy. I can fit underneath without lifting the vehicle. The oil is so thin 0-W-20 it drains fast. Filter is easy to change as well.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
2014 F150 with a 4” lift is easy to drain and the filter is easy to swap, but when you remove the filter, it drips down on the K member, and then onto the ground. There’s a little plastic tray, but it doesn’t catch it at all.
Sometimes I use ramps and sometimes I don’t. |
easiest - one i pay for.
hardest - one i do myself. especially when i can't get a strap wrench on the filter. or better (red tr6 i'm looking at you here) it's too old for a canister and you get covered with oil undoing the filter housing. |
