Honda Accord overheating problem?
My temp guage blasted to max this morning and the warning lights started flicking. I immediately pull over. I noticed a puddle of antifreeze next to the car. Anyways, dad pulls up, I upt some water in my radiator and add oil as well. I then drive about 10 mins and park and then let the car idle. No leakage or anything, even with motor idling. I then drive to parking garage with no issues. Any idea what could be happening. If I had a leak, I would expect the fluid to leak out and form a puddle. Any thoughts on where to look. I had the radiator replaced probably 2 years ago. Not sure why it would puddle and then not puddle.
Thanks, David |
D idn't E arn I t
Random overheating is a sign of failing head gasket. Have it pressure tested. Also, water pump impellers are known to rot out if the coolant isn't maintained -
rjp
In the movies only bad guys sleep in king size beds. |
It couldn't be the car's fault, Honda Accords don't break
Could also be a crappy thermostat. $10 bucks at NAPA would put that possibility to rest. Also, you may want to verify that your electric cooling fan is turning on via the thermostatic switch. These switches are typically located at the bottom of the radiator and go bad often.
Warren & Ron, may you rest in Peace. |
Banned
The puddle was likely from your coolant overflow tank "over flowing."
It is common when cars get that hot. My guess is the T-Stat. |
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats |
I'm with Bill
Thermo switch for the Electric fan has gone bad. Common problem on Hondas. Replace the sending unit and it should fix the problem.
I had this broblem with both Hondas I owned and just hotwired the fan to run all the time. I am in Florida so it isn't cold enough here to hurt. I would not do that up North.
1978 Mini Cooper Pickup 1991 BMW 318i M50 2.8 swap 2005 Mini Cooper S 2014 BMW i3 Giga World - For sale in late March |
